Russ Knight
I am considering adding nitrous to my engine build. I do not want to alter the 6 pack manifold. Does anyone make a spacer plate nitrous setup for the small block 6 pack?
Yes, but I forget who, ...My buddy Mike had them for His AAR, but hasn't used them. Ended up putting a 408" stroker in it w/LA-X Heads & a bigger cam instead.I am considering adding nitrous to my engine build. I do not want to alter the 6 pack manifold. Does anyone make a spacer plate nitrous setup for the small block 6 pack?
It went from a best of 12.30's @109+ with the 340 & T/A heads I did a mild port job on, to a 'so far' best of 11.90 @114 w/the new setup, but it was running way rich now. He's stepped the jetting down & it cleaned up & smoothed out, but I'm sure there's a good bit in there to unlock yet.I'm doing something like that too.![]()
Thanks for the info!It went from a best of 12.30's @109+ with the 340 & T/A heads I did a mild port job on, to a 'so far' best of 11.90 @114 w/the new setup, but it was running way rich now. He's stepped the jetting down & it cleaned up & smoothed out, but I'm sure there's a good bit in there to unlock yet.
My memory is telling Me the NOS plate setup only sprays the outboards, the center plate is just a spacer to level it up, IIRC.
The 340 was 9.7:1 & ran a Purple shaft 292°/.508" cam with the original tight LSA. Not sure of the squeeze on the stroker, & cam is right around .600" lift.
I'll take it...
From my cold dead handsI'll take it...
I assume so, but I'm not a machinist. But check this out. I ain't paying that....Making those plates can't be that hard. I could make em with my mill in a day. The rest is just standard NOS parts, isn't it?
That NX system is 1 plate in center and 2 spacers.I assume so, but I'm not a machinist. But check this out. I ain't paying that....
Six Pack Nitrous Kit
Holy donkey balls, that's crazy, and only one plate has spray.I assume so, but I'm not a machinist. But check this out. I ain't paying that....
