/6 QRS engine
Slant 6 Engines
  1. bigaadams
    bigaadams Well-Known Member
    279
    110
    Apr 25, 2015
    GA
    Local Time:
    7:44 AM
    what parts/build defined the slant six QRS engine....?
  2. toolmanmike
    toolmanmike Moderator Staff Member FABO Gold Member
    62,404
    51608
    Jan 18, 2006
    Iowa
    Local Time:
    7:44 AM
    What's QRS?
    • Agree Agree x 2
    • pishta
      pishta I know I'm right....
      21,388
      10777
      Oct 13, 2004
      Tustin, CA
      Local Time:
      5:44 AM
      some slants had a double roller chain and stellite exhaust valves.
      ...special versions for industrial, commercial, and marine use; these had special equipment such as two-row timing chains, chrome-plated upper piston rings, valve rotators, Stellite-coated exhaust valves, high-volume oil pumps, and polyacrylic valve stem seals ...
      • Thanks! Thanks! x 3
      • bigaadams
        279
        110
        Apr 25, 2015
        GA
        Local Time:
        7:44 AM
        but did this define the QRS.......I admit I have no clue.....but was clearly depicted on the 73 Dart Custom I owned from new and as such delivered with the decal. This little car was notorious for chirping second gear on an automatic shift of the tranny....all you had to do was give it the gas...and hold it down....second gear....little chirp from the tire....
        pishta....did not mean to gun deck you as they say....I should have define the question a bit by stating what I have written below this.....
        The car was Canadian built and while I cannot say for certain as it has been so many years I am thinking the full decal was Windsor QRS
        • Like Like x 2
        • bigaadams
          279
          110
          Apr 25, 2015
          GA
          Local Time:
          7:44 AM
          I see the big ? and that is basically what I asked....what is QRS and if I knew I clearly would not be asking....it was what my engine had written on it is all I can say.
        • pishta
          21,388
          10777
          Oct 13, 2004
          Tustin, CA
          Local Time:
          5:44 AM
          OOh, they cast some slants in Canada....Maybe that's the name of the foundry.
          Q probably was for "quality, R and S somthing else.....
          • Like Like x 1
          • pishta
            21,388
            10777
            Oct 13, 2004
            Tustin, CA
            Local Time:
            5:44 AM
            Holmes foundry in Ontario was where some slants were cast. Assembly was somewhere else, probably Windsor.
          • bigaadams
            279
            110
            Apr 25, 2015
            GA
            Local Time:
            7:44 AM
            yes, the slant engines was built at the Windsor plant in Canada as was many A engines...it could be simple as QUICK RELIABLE STARTING (see below..lol) but for some reason I am thinking it for something else...if were on the say the radiator shroud or say glove box door thne maybe QUIET RIDE SUSPENSION....but on the engine....it is just a quess and was hoping a slanty fan would have the answer. The Canadians use some of their own castings to satisfy home grown requirement for shared facility. Just something of interest that may never get the real data for.
            The 1973 model year Darts.......Chrysler's new electronic ignition system was standard equipment on all engines, and starter motors were revised for faster engine cranking.
          • volaredon
            volaredon Well-Known Member
            1,028
            323
            Feb 28, 2010
            IL
            Local Time:
            7:44 AM
            could this be a reman and that being some logo from whoever rebuilt the engine?
          • bigaadams
            279
            110
            Apr 25, 2015
            GA
            Local Time:
            7:44 AM
            entry #4 bought new off showroom floor by myself........
          • Dorian
            Dorian dorian
            843
            85
            Jan 28, 2006
            Medicine Hat, Alberta, Ca
            Local Time:
            7:44 AM
            too late to be a quadrophonic realistic stereo...
          • bigaadams
            279
            110
            Apr 25, 2015
            GA
            Local Time:
            7:44 AM
            as I recall, working as a wrench for brand L....the quads hit big about 75......
          • pishta
            21,388
            10777
            Oct 13, 2004
            Tustin, CA
            Local Time:
            5:44 AM
            we had a 76 Lincoln Towncar with Fords Quadraphonic stereo...said it right on the AM/FM slider bar. That car has HUGE!
          • Ricks70Duster340
            Ricks70Duster340 Child of the King FABO Gold Member
            638
            426
            Feb 8, 2021
            Sisterdale, TX
            Local Time:
            7:44 AM
            Yeah, they were boats!
          • pishta
            21,388
            10777
            Oct 13, 2004
            Tustin, CA
            Local Time:
            5:44 AM
            232 inches...19.5 feet...(insert ship horn here)
            73 Imperial LeBaron was 3 inches longer!
          • my68barracuda
            my68barracuda Well-Known Member
            2,050
            1899
            Dec 6, 2009
            Indianapolis IN
            Local Time:
            8:44 AM
            I had a buddy that had a Lincoln Town Car back in the late 70’s. We use to quip that it was a ‘Town Car’ because it used way to much gas to drive it out to the country.
            • Agree Agree x 2
            • Ricks70Duster340
              638
              426
              Feb 8, 2021
              Sisterdale, TX
              Local Time:
              7:44 AM
              I remember the suspension was so much like a marshmallow that when they stopped they kept on rocking a little. Boatmobiles all of them!!!
            • slantsixdan
              slantsixdan =..=
              6,831
              2128
              Jan 7, 2007
              Vancouver BC
              Local Time:
              5:44 AM
              Quintessence Retroencabulation System. Even ask god.
            • bigaadams
              279
              110
              Apr 25, 2015
              GA
              Local Time:
              7:44 AM
              I happened upon my original owners manual for the car....not a mention at all....someone knows....but knowing that someone may never happen...thanks all for playing along.....remember the show....Stump the Stars.....its still alive and well it seems.....!:lol:
