The top of the passenger door toward the frt fender hitting the door post the hindge is bolted to. Are there shims available or an adjustment I can do to bring the top hinge out from the body?
I don't think you need any shims. It's not easy, I know. Just tape all your jams and use some wood shims in the gaps and you should be able to get it right. Unless you have some collision damage or rust.
Thanks for the advice. I actually made the adjustments today and it worked out great. Appreciate your taking the time to help, worked like a charm!! Thanks again, Ken
