Mineallmine
Got my car currently on my rotisserie getting the underside cleaned and painted and was looking at my rear diff as its next to tackle. I am planning on replacing the front seal (pinion nut as well of course), diff fluid and gasket, as well as all the leaf spring bushings while it is out. This is where my question comes in.
I have been looking on line for bushings and am able to find the rubber bushings for the rear I believe (smaller ones for shackle and spring...these are the same? correct?) I am not having a lot of luck finding the fronts. I was considering the poly bushings but hear so much conflicting info on noise from them, harder ride, etc. I am keeping the car stock with the little 170ci slanty so performance driving is obviously out.
Can anyone point me in the direction for who makes the best bushings for these (poly and rubber I guess as I may still go poly) as in fit and quality? Thanks in advance.
I have found moog rubber bushings but it says for rear shackle only. Is the rear eye of the leaf spring different? From looking at the poly mounts I didn't think so. I still have to pull the front bracket off to determine the front bushing diameter as I have seen from searching there is a 1 1/2 inch diameter and a 2 inch diameter front eye. Is one more likely than the other to find in my 63 170 dart?
Thanks again
Thanks again
