63 Valiant new brake lines...where do these clips go?
B-i-n-g-o
North Carolina
Need to bug y'all again, please!
Installing new brake lines, and I got a brake clip set. Rear end done, and I think these are all for the line front to rear. The old lines were a little ragged...I found all the spring clip locations but one, but there are two bolt-on clips, that weren't on the old lines, so no idea where these go. I'm not going for concourse grade, but I want to do it as right as I can, and more mounts for brake lines, probably better! If someone could take a reference photo or describe whereabouts they go, I'd appreciate it!
Thanks,
Steve
Thanks,
Steve
They look like the ones mounted on the right rear frame rail holding the fuel line.
Appreciate it! If I can't find a brake line home for them, I've redone the fuel lines already, but the old ones were...uh...,'not to factory specs', so I'll see if I can use them on the fuel!
