1. Claydart
    Claydart MOPAR to the very bones FABO Gold Member
    373
    211
    Mar 27, 2013
    Brockton, Ma.
    Local Time:
    11:51 AM
    How much can I adjust my kickdown to kick in without it breaking something?
  2. toolmanmike
    toolmanmike FABO MODERATOR Staff Member FABO Gold Member
    48,443
    33067
    Jan 18, 2006
    Iowa
    Local Time:
    11:51 AM
    It won't break anything, it just won't upshift. I always adjust mine up for a slightly higher rpm shift.
    • Like Like x 1
    • 65Val
      65Val Average Length Member
      5,049
      1017
      Oct 14, 2005
      Victoria, BC, Canada, EH!
      Local Time:
      9:51 AM
      You can adjust it way up there, but at some point the k/d linkage will prevent the throttle from fully opening...that would be too much!
      • Agree Agree x 1
      • cosgig
        cosgig MoBro Inc. FABO Gold Member
        11,252
        4283
        Jul 20, 2008
        Pinckney, Michigan
        Local Time:
        11:51 AM
        If you’re still running the original linkage, I would consider going to the later style 3 piece linkage with the slotted slider rod at the carb. It has more adjustment, and is a much safer setup.
      • Claydart
        373
        211
        Mar 27, 2013
        Brockton, Ma.
        Local Time:
        11:51 AM
        Mine was adjusted so that I had to just about stand on the pedal to get it to downshift. So I took it out for a ride yesterday, and tried it on a nice and clear road and stood on it. I really had to apply pressure with my foot to get it to downshift. So I got it home and popped the clip off the rod and screwed it out about four or five turns and took it back out for a test drive. It shifted at about 7/8 of the way to the floor. Should it be any higher than that?
      • oldkimmer
        oldkimmer FABO Gold Member FABO Gold Member
        14,830
        3903
        Nov 11, 2006
        Kindersley, Saskatchewan,
        Local Time:
        11:51 AM
        That’s about right as long as the carb opens and closes all the way. Kim
        • Agree Agree x 1
        • CudaFactHackJob
          CudaFactHackJob FABO Gold Member FABO Gold Member
          1,087
          376
          Mar 17, 2016
          Hemet, Ca.
          Local Time:
          11:51 AM
          The kd arm is supposed to be all the way back when the carb is all the way open. That's where you start.
