64 Valiant 273 w/ electronic ign. Engine bay wiring pics needed
Cudabnu
(3) 64 Val Verts. /6 4spd, 273/904, 318/727
Moorpark, CA
My 64 came apart in boxes, new wiring harness, converted to electronic ignition. Looking for pics of routing, where to mount the ballast/voltage regulator/control box, starter relay, horn relay. also looking for pics of the correct bolts to mount the above stuff.
What type of electronic ignition? Most of the components you mentioned should go right in the stock location. Once you string the wiring harness in it's clips, you should see where each one is mounted. The only extra will be the ignition control box if it has one. Mount that wherever you can and still plug it in without having to lengthen wires.
