[Found!] '64 Valiant Convertible driver rear quarter window regulator.
BobW
Curmudgeon At Large
Central, FL 34705
My Driver side rear Quarter window regulator has 90% of the splines stripped. I've cleaned & lubed the mechanism so it works smoother, but I'd like to find a replacement regulator if I can.
Has anyone rebuilt splines using epoxy/JB Weld?
I was thinking of mixing some up putting on the spline shaft, covering it with plastic wrap and installing the crank. :eek::rolleyes::)
