[FOR SALE] '65 and earlier A body speedo cable
Mojack
Bristol, Tn.
I've got a speedo cable that came out of a '65 Barracuda for the early type of drive gear. I left the gear on it to help identify it, but the gear is hurt on one side. You might get it cleaned up enough to work. I can provide a new oring before I ship. The cable spins freely, but I'm sure it could use a little lube before you install it. No kinks. $25+shipping from Bristol Tn. 37620
Gears are based on the transmission side, do you know what size Transmission the cable was removed from. Also I have a 65 and there are two different speedo's that can be in the dash, 80 mph or 120 MPH, so identify both ends may help.
It came from a shell that was turned into a nostalgia gasser so I can't be sure of its options. You can still access the pics by clicking on the jpg numbers above, maybe that will help with identification. Thanks
