65 Barracuda, 225 vs 170 motor mounts.
Slant 6 Engines
  1. circlepilot
    circlepilot FABO Gold Member FABO Gold Member
    419
    221
    Nov 15, 2014
    El Dorado, Arkansas
    Local Time:
    9:29 AM
    I've encountered a problem with motor mounts, on my 65 Barracuda restoration. My fender tag and broadcast sheet indicates that my engine is a 225. (20) I ordered the left and right motor mounts based on that information. A2265 (left) and A2264 (right). When they arrived it was obvious the were not like the ones that are in the car now...A2303 (left) and A2304 (right), these are being shown to be for the 170. I haven't checked the engine serial number...didn't give it a thought to see if it had been changed out. Am I dealing with an engine swap, or a parts problem?
    Norm
  2. Charrlie_S
    Charrlie_S Well-Known Member
    2,425
    394
    Oct 17, 2005
    Silver Springs, FL
    Local Time:
    10:29 AM
    You are dealing with a aftermarket Part Manual srew up. The correct "Insulators" (mounts), for either the 170 or 225 slant six in a 63-66 "A" Body are the A2203 and A2204.
    The mounts you recieved (A2265, A2264) are for a 67-72 "A" body (plus other applications). This is a common problem with the part catalogs. The catalogs are correct for a Dodge Dart, but incorrect for a Valiant/Barracuda. I gave up years ago, telling the parts suppliers the catalogs are wrong.
    • Thanks! Thanks! x 1
    • memike
      memike Super Moderator Staff Member FABO Gold Member
      48,910
      8935
      Jan 8, 2006
      on the hill
      Local Time:
      9:29 AM
      I have a set of good mounts I took off of my 66 Valiant 170/ , here is what they look like
      01ccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccc.jpg
      • circlepilot
        419
        221
        Nov 15, 2014
        El Dorado, Arkansas
        Local Time:
        9:29 AM
        Thanks Guys...Yep! memike, that's what's in there. The 2203 and the 2204 will be here Monday (as soon as I got the others, I re-ordered) and I'll send the others back. We have the same problems with some of the aircraft parts we order.
        Norm
      • slantsixdan
        slantsixdan =..=
        6,110
        1148
        Jan 7, 2007
        Vancouver BC
        Local Time:
        7:29 AM
        Rather than use the compressed-cow-poo-from-India toys shaped like engine mounts, get these and never ever worry about your mounts again.
        • Bill Dedman
          Bill Dedman bill dedman Legendary Member
          4,010
          52
          Oct 16, 2007
          Conway, Arkansas
          Local Time:
          8:29 AM
          Good advice!!!!
