65 Barracuda Barn Find
Early A-Body Discussions
  1. Backaroota
    Backaroota New Member
    3
    10
    Jan 17, 2021
    Clarkston,WA
    Local Time:
    12:40 AM
    I purchased this baby blue 65 Barracuda a few months ago. It belonged to this guys mother who bought it new. She passed away 20+ years ago and he just parked it. It has no dents or rust, None. Interior is in great shape, one mouse nest. I got the brakes fixed pored some gas down the carb and drove it. The old gas smelled like Napalm I'm amazed it ran.
    I do have a couple of questions. I'm rebuilding the 273. The #4 main bearing was about to fail so the crank needs to be replaced. Where can I purchase a new crank? Also I replaced the gas tank and sending unit but the gas gauge doesn't work or the temp. The temp gauge has the little wire to the heater burned out. Where can I purchase new ones?
    I'm a Chevy guy. I drag race a low 10 sec 67 Nova. I'm not use to not having parts available.
    • Like Like x 2
    • Valkman
      Valkman FABO Gold Member FABO Gold Member
      941
      310
      Sep 13, 2012
      NC
      Local Time:
      3:40 AM
      Any 273, 318, 340 (except 72,73) will fit. The older ones are forged, but a cast one will work as well. Eagle & Scat sell new ones.
    • Valkman
      941
      310
      Sep 13, 2012
      NC
      Local Time:
      3:40 AM
      Check tbe voltage regulator behind the dash, it steps the voltage down to 5v for gauges
      There's lot of good info on this forum, do some searches and get a lot:thumbsup:
    • 66340SEDAN
      66340SEDAN FABO Member #3649
      29,411
      39750
      Nov 20, 2006
      Minnesota
      Local Time:
      2:40 AM
      Awesome....have any pictures of the car?
      • Agree Agree x 2
      • Plymouth 65
        Plymouth 65 Floorable Deplorable
        1,439
        1375
        Jun 27, 2016
        Mich
        Local Time:
        3:40 AM
        The early 273 has the small diameter register at the end of the crankshaft. 65'
        • Like Like x 1
        • dicksmidlac
          dicksmidlac Well-Known Member
          362
          781
          Jul 6, 2005
          Thunder Bay Ont
          Local Time:
          2:40 AM
          Couldn’t you just get the crank reconditioned if it’s not too bad?
          • Agree Agree x 5
          • cudamark
            cudamark FABO Gold Member FABO Gold Member
            8,053
            929
            Mar 14, 2009
            San Diego
            Local Time:
            12:40 AM
            Turn the crank if possible even if you need to have that journal welded up and turned. If it's beyond hope, any other crank you put in there and it would be wise to rebalance the engine. All 318 cranks and any engine crank '68 and later will have the large converter register, so, you'd also need a reducer bushing for your early converter. That year should have the IVR (instrument voltage regulator) incorporated into the fuel gauge. Either have it rebuilt, replaced, and/or converted to a solid state electronic regulator. It supplies juice to the temp gauge, so, it may have ruined that gauge too. An ohmmeter test will tell the story.....at least part of it.
            • Agree Agree x 1
            • JDMopar
              JDMopar Well-Known Member
              3,916
              2852
              Jan 19, 2012
              Candler, NC/Myrtle Beach, SC
              Local Time:
              3:40 AM
              Just have the 273 crank turned. It will save you the trouble of having to hunt one of those spacers for the snout on the converter. If you plan on adding a 4 barrel carb, be prepared to oval the holes out to make any aluminum intake sold new, fit the heads. 64-65 273 motors had the intake bolt holes drilled at a different angle than 66 and up LA Mopar small blocks, and the intake bolts were 5/16 instead of the later 3/8 bolts. You could probably find an Edelbrock D4B intake that was made for the 64-65 273 back in the day, but prices on those are :realcrazy:! I'm quite sure you know your Chevy stuff inside and out, and fixing up a 65 Barracuda will frustrate you to no end because there's not a lot available. There's a lot of knowledge here, so don't be ashamed to ask for help. Heck....some of us may need you to return the favor if we need Chevy help! Welcome to FABO. :)
            • Tooljunkie
              Tooljunkie King of cobble/master of the broken bolt FABO Gold Member
              17,930
              18609
              Jul 22, 2017
              Manitoba
              Local Time:
              2:40 AM
              A few difficult things to deal with, dual cable shift transmission,ball and trunnion slip yoke at transmission. If you are lucky, this stuff may still be in good shape. the first early barracuda i saw was a baby blue one. My sisters friend drove it.
            • jos51700
              jos51700 Hemi Orange you glad it isn't a political avatar?
              5,553
              2269
              May 24, 2009
              Bel-Ray
              Local Time:
              2:40 AM
              First off, nice thread with no pics. We got rules here, man.
              Second, how do you know what Napalm smells like?
              C: Stroker crank. Get on it. Small bore, no valves, long stroke = torque. I think. Either way, stroker crank.
            • JDMopar
              3,916
              2852
              Jan 19, 2012
              Local Time:
              3:40 AM
              Wait? Is First, Second, C the same thing as A, B, Third? :rofl:
            • A56
              A56 MoParAffliction FABO Gold Member
              4,419
              9525
              Jun 24, 2014
              South of the Mason-Dixon Line
              Local Time:
              1:40 AM
              :popcorn::rolleyes::lol:
            • Backaroota
              3
              10
              Jan 17, 2021
              Clarkston,WA
              Local Time:
              12:40 AM
              Thanks for all the good info. I'm taking the motor to my machinist today. Sense the car is bone stock I want to keep it that way. Hopefully we can get the original crank turned.
              The pictures are of my Nova. My son's drag truck. I put a 528 in it. And the 62 Falcon Gasser I built for my daughter.
              • Like Like x 5
              • ZooKypr
                ZooKypr Well-Known Member
                1,867
                184
                Jul 5, 2009
                NJ
                Local Time:
                3:40 AM
                Welcome to E.B.A..... Early Barracuda Annomynous.
                We feel and live thru your pains of the oddities and lack of parts for these bubble back beasts. Rest assured we are here to easy your transformation into MOPAR MANIA!
                BTW...nice rides
              • ZooKypr
                1,867
                184
                Jul 5, 2009
                NJ
                Local Time:
                3:40 AM
                Your 65 looks nicely preserved...side trim and hood spear are nice touches but not factory. Beautiful center grill! Can't go wrong with baby blue paint!!! Good luck with her.
              • clementine
                clementine Flight risk FABO Gold Member
                1,023
                541
                Jan 3, 2016
                Emerald city
                Local Time:
                12:40 AM
                thank goodness we got pics....i was starting to panic...
                • Like Like x 1
                • Backaroota
                  3
                  10
                  Jan 17, 2021
                  Clarkston,WA
                  Local Time:
                  12:40 AM
                  Making progress. Got the motor out and to my machinist. It had a couple of problems. First #4 main bearing fell out when I removed the cap. It was pretty close to catastrophic failure. We sent it off to be reground. The other problem was one of piston wrist pin retainer had broken and scared the cylinder wall. We where able to bore it .060 over and I found a set of pistons on eBay.
                  The engine bay is painted and I'm starting to put things back on.
                  The spear on the hood looks factory. But the side spears look like they where added at the dealer.
                  • Like Like x 3
                  • Ciguatera
                    Ciguatera FABO Gold Member FABO Gold Member
                    30
                    14
                    Apr 28, 2017
                    Virginia
                    Local Time:
                    3:40 AM
                    Stroker crank! I'm not alone! I'm seriously thinking of stroking my 273 but I've been afraid to post anything about it because people would think I'm insane.
                    What a beautiful blue cuda the OP has! My '65 doesn't have a hood spear so that may be from the dealer too.
                  • RustyRatRod
                    RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
                    70,700
                    45570
                    Jun 7, 2010
                    Georgia
                    Local Time:
                    3:40 AM
                    Love the Falcon! I have a 61. Nice Barracuda!
                  • Valkman
                    941
                    310
                    Sep 13, 2012
                    NC
                    Local Time:
                    3:40 AM
                    I have a 410 stroker in mine, "insane" maybe but it sure is fun!:steering:
                  • toolmanmike
                    toolmanmike FABO MODERATOR Staff Member FABO Gold Member
                    58,132
                    45221
                    Jan 18, 2006
                    Iowa
                    Local Time:
                    2:40 AM
                    Stroker in a early Barracuda? Ed is a member here. Not a 408 either. But I don't think it's a 360 crank.
                  • dibbons
                    dibbons Well-Known Member
                    4,900
                    2848
                    Nov 6, 2009
                    La Paz, B.C.S., Mexico
                    Local Time:
                    12:40 AM
