65 barracuda drum size
autumn ash
Member
Texas
Hey, can somwone let me know the drum size.
From one side to another in the smallwr ring its 10.4 ish so does it round down to a 10 inch drum?
toolmanmike
Moderator
Staff member
Office
^^Yes- measure the inner diameter (the friction surface), that will tell you the size.
^^^^^^^^^^^^^^^ THis^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
It is either a 9" or 10" Unless a previous owner changed something.
chewy
Vegas Dart
North Las Vegas NV
The good news is at 10.4 on a 10", looking at the thickness in the pic, you have plenty of room 0.20 to have these turned and don't need to buy drums yet.
autumn ash
Member
Texas
Im not planning on using these drums i just want to know if i have 10 inch spindles so i can buy wilwood disc conversion.
RustyRatRod
I was born on a Monday. Not last Monday.
Georgia
It appears to be a 10" drum, but you need to measure from the right place in order to get the correct number.
cudamark
San Diego
A photo of the spindle will settle that issue. Also, the 9" brakes use A1 and A4 bearings......The 10" brakes use A2 and A6 bearings.
pishta
I know I'm right....
Tustin, CA
Those drums are worth pawning off even if they need turning if they are 10's.
pishta
Tustin, CA
You'd have to get them mic'd and sell them as turntable as they are not that easy to find serviceable or new l. The come up for sale new from CHINA time to time but they seem to be limited runs.
autumn ash
Member
Texas
Hmmm good to know.
bcschief
Crescent City Florida
View attachment 1716011908Couldn’t find mine so a copied a pic from the web. I think I loaned it out.
Just for future reference the spindles pictured are 10 inch spindles, 9 inch have the upper ball joint stud boss twisted 90 degrees.
S'cuder
Living in my own Private Idaho
Planet Claire
Be aware that the Wilwood hub is larger, and many factory wheels won't fit. There's several threads on the forum you can research that detail this. As long as you know what you're getting going in, you can plan for a satisfactory outcome. Several people have made the purchase and found out the hard way they needed new wheels.
Good luck!
autumn ash
Member
Texas
Good luck!
Yeah im going to conver to the larger bolt pattern, looking at american racing wheels.
GGs66GT
Shasta Lake, Cal.
You can save a bunch of bucks by using’73 - ‘76 a body upper control arms, spindles, lower ball joints , rotors, calibers .
