65 Barracuda Dual Exhaust Stainless
68HAVOK
Modesto
Got the exhaust done on the 65! My buddy knocked it out of the park in my opinion.
Love them welds, super clean! That X pipe will really mellow out the pulses.
That's is gorgeous. That guy sure has some nice welds, and the placement of the mandrel bent exhaust pieces is perfect.
Yeah....those damn Mopar Performance Cast Aluminum one are the problem. Its next on the list to get taken care of.
I've found the biggest problem to be the gasket surface on the LA heads. When I was a machinist, I used to mill, the valve cover surface of the head, flat. Never had a leakage problem after that.
If you have a PCV problem it can cause pressure to build in engine and make things leak worse.
