[WANTED] 65 barracuda interior trim-below rear glass
Cars and Mopar Parts Wanted
Thread Status:
  1. Lurch59
    Lurch59 Well-Known Member
    144
    85
    Aug 7, 2021
    South Dakota
    Local Time:
    7:52 PM
    Contact Seller
    I am looking for trim, I believe 3 pieces total, that attaches across the back glass and 2 L-shaped curved pieces that are associated with it.
  2. 66340SEDAN
    66340SEDAN FABO Member #3649 FABO Gold Member
    22,387
    17283
    Nov 20, 2006
    Minnesota
    Local Time:
    8:52 PM
    These pieces the plastic ones inside under the glass and the 2 ā€œLā€ shaped ones at the front inside bottom corner?
  3. Lurch59
    144
    85
    Aug 7, 2021
    South Dakota
    Local Time:
    7:52 PM
    I think we are talking about the same trim pieces. The interior piece under the glass has 4 oblong vents (I presume they are vents) and the contiguous pieces on either side. I don't see pictures if you posted any. Thanks
    I described them as L shaped but perhaps just curved transition pieces are a better description.
  4. cudamark
    cudamark FABO Gold Member FABO Gold Member
    9,274
    1622
    Mar 14, 2009
    San Diego
    Local Time:
    6:52 PM
    If you're talking about the plastic curved pieces, those are pretty hard to find that aren't broken. They get as brittle as potato chips after 55+ years in the sun.
    • Agree Agree x 1
    • 69FBCuda
      69FBCuda I'm so confused! FABO Gold Member
      3,322
      1839
      Aug 28, 2014
      Florida
      Local Time:
      9:52 PM
      This what your looking for
      • Agree Agree x 1
      • Lurch59
        144
        85
        Aug 7, 2021
        South Dakota
        Local Time:
        7:52 PM
        • Like Like x 1
        • pishta
          pishta I know I'm right....
          21,804
          11235
          Oct 13, 2004
          Tustin, CA
          Local Time:
          6:52 PM
          Yup. been looking myself. Thought someone was gonna repop them but no go. You can possible make something with vinyl floor edging and a heat gun. Or Cover the entire back support with same thick material and make holes in it for the ventilation. Looked kinda incomplete stock anyway.
        • Lurch59
          144
          85
          Aug 7, 2021
          South Dakota
          Local Time:
          7:52 PM
          Well, it's dark half the time so only like 27.5 years in the sun. We need repro parts!
        • Lurch59
          144
          85
          Aug 7, 2021
          South Dakota
          Local Time:
          7:52 PM
          If we do find some, they probably won't be rusty! I'm looking for a bright side, here...
        • Tooljunkie
          Tooljunkie King of cobble/master of the broken bolt FABO Gold Member
          20,557
          22978
          Jul 22, 2017
          Manitoba
          Local Time:
          8:52 PM
          The earth reclaimed mine too. And the small ones at the front corners. Going to hammer some out of sheet metal. Or maybe fiberglass.
        • cudamark
          9,274
          1622
          Mar 14, 2009
          San Diego
          Local Time:
          6:52 PM
          I might have some chipped ones, but, no perfect ones for sure. The problem would be the shipping. It would probably take a fairly good size box to protect them, or, you'll end up getting a box of crumbs.
        • Big_John
          Big_John In my defense, I was left unsupervised.
          470
          645
          Nov 16, 2014
          Syracuse, NY
          Local Time:
          9:52 PM
          The center piece doesn't come off, its part of the structure.
        • Lurch59
          144
          85
          Aug 7, 2021
          South Dakota
          Local Time:
          7:52 PM
          Not likely to be reproduced when so few are being restored, I suppose. I will see if the resto shop has any ideas. We must be getting close to scanning an original piece and 3D printing it, no?
        • Lurch59
          144
          85
          Aug 7, 2021
          South Dakota
          Local Time:
          7:52 PM
          I just looked and it is part of the structure. I just saw 4 screws very near where the window gasket goes, and assumed that held the trim on. I wonder what the 4 screws attach to?
        • Lurch59
          144
          85
          Aug 7, 2021
          South Dakota
          Local Time:
          7:52 PM
          Thanks for the lead. Let me see what they can do at the hot rod shop that is going to assemble the stuff. Yours might be important to make a pattern.
        Thread Status:
