I don't think so. But like you said, if the overall is 11'' inside should be 10"Can’t know without popping the drums off? I read there was supposed to be markings on the outside of the drum that indicate size?
It did have 13”. All 65s had 13s. Even the Chargers with Cragars. It has 14” Rallyes right now.i had a 65 273 dart, it had 10" drums on it, it was a hipo 273, does yours have 13 wheels?
Aren't all the 9 inch front drums the ones with fins all over them?
Yeah the finned ones are later and the non finned ones are from the early 60's up to around 68 or there about . They interchange
And it's hard to believe those drums are that far out of balance. Those weights will prevent some wheels from fitting flat on the hub.
So, you've added QA-1 control arms & KYB shocks but your still running 9" drums??? WTH???
That looks like a 10". Some are stamped with the max diameter allowed on the flat surface between the studs. It only takes a few minutes to pop the grease cap off, remove the cotter pin and outer bearing, then slide the whole hub and drum assembly off. If you're going to do a brake job, you're going to need to know whether the drum is still within specs anyway. You'll also want to check the condition of the brake hardware, wheel cylinder, and bearings, so, pull it off and check everything.
Re the brake drums all 65 A-bodys had 9" drums up til mid October when 10" brakes arrived on the scene w/273 V8 or heavy duty brakes.
I measured them. They are definitely 10”.You will need to measure. Couple be either.
I was thinking the same thing. As small as they are, how could they be? lolAnd it's hard to believe those drums are that far out of balance. Those weights will prevent some wheels from fitting flat on the hub.
