1. nearpar
    nearpar Well-Known Member
    229
    43
    Sep 14, 2018
    The Motor City
    Local Time:
    11:40 AM
    I removed my remote Mirror on the 65 Dart and noticed that the metal under the mirror base on the door is raised. My question is is this normal or do I need to do some hammer work?
  2. toolmanmike
    toolmanmike FABO MODERATOR Staff Member FABO Gold Member
    49,625
    34422
    Jan 18, 2006
    Iowa
    Local Time:
    10:40 AM
    Need to see a picture.
  3. bigaadams
    bigaadams Well-Known Member
    270
    104
    Apr 25, 2015
    GA
    Local Time:
    10:40 AM
    many times the mirror mounting surface is not backed with a nut plate that would sandwich the door skin between the nut plate and the mirror base. In such application distortion of the skin metal is common and will cause a rise due to the incline plane of the screw when torque is applied. The question here on if/should is are you going back with the same mirror and screw and did the mirror hold tight before removed. I would probably just back the hole and level with a light tap if utilizing same mirror and attachment means. If I have suspect of weak metal and know the screw may not hold, I most always use a nutsert in the hole and swap to a stainless machine screw. What level method you chose will work just what are you comfortable with is the call you have to make.
  4. nearpar
    229
    43
    Sep 14, 2018
    The Motor City
    Local Time:
    11:40 AM
    • Like Like x 1
    • nearpar
      229
      43
      Sep 14, 2018
      The Motor City
      Local Time:
      11:40 AM
      Thank you for the information I will take a good look at that
