65 dodge dart 270
Early A-Body Discussions
  1. Dennis Richardson
    Dennis Richardson Member
    15
    1
    Apr 24, 2017
    Illinois
    Local Time:
    11:26 PM
    What's the best way to update front suspension. Any thoughts on tube type k-members like AJE . Car is going to be street car.
  2. BillGrissom
    BillGrissom Well-Known Member
    7,212
    325
    May 10, 2009
    Sacramento
    Local Time:
    9:26 PM
    The K-frame isn't very heavy, so doubt you would save much weight w/ a tube type. Tubular upper control arms have adjustable mounts so you can set caster better for radial tires. With the factory UCA, you must use Moog offset bushings to get caster right. Forget the PST poly LCA bushings. They seemed hokey since the LCA could then slide backwards, and I recall PST even stopped selling them. Some people cut off the factory frame rails and weld on a coil-over suspension kit, I think some w/ rack & pinion steering, but >$3000 and irreversible. I recall some that bolt on instead, but I don't venture in those play-pens.
    • Like Like x 1
    • Dennis Richardson
      15
      1
      Apr 24, 2017
      Illinois
      Local Time:
      11:26 PM
      Thank for the input. I'm going with adjustable control arms. Saving original k-member.
      • Agree Agree x 1
      • Valkman
        Valkman Well-Known Member
        794
        228
        Sep 13, 2012
        NC
        Local Time:
        12:26 AM
        It all depends what how you're going to drive the car and what you want out of it? IMO the stock Chrysler suspension is pretty good as is (when is good condition). Again What do you want to get out it?
        • Like Like x 1
        • Dennis Richardson
          15
          1
          Apr 24, 2017
          Illinois
          Local Time:
          11:26 PM
          Just cruise and show. Maybe some race days
        • Valkman
          794
          228
          Sep 13, 2012
          NC
          Local Time:
          12:26 AM
          I'd just rebuild what you got. Things like anti-sway bars, adjustable control arms, poly bushings, frame connectors, and other things like larger wheels may make it handle better, but will stiffen the ride a good bit as well. Brakes would be a good upgrade if not anything else.
        • Valkman
          794
          228
          Sep 13, 2012
          NC
          Local Time:
          12:26 AM
          Some of the mods I did on my 65 where front and rear anti-sway bars, sub frame connectors, 17" performance tires and big front disc brakes and car handles and stops pretty good for an old girl. The ride is a on the stiff side but it's barable. I also aready had tge heavy-duty suspension in the car to begin with
        • gregsdart
          gregsdart Well-Known Member
          585
          145
          Jun 20, 2004
          mn
          Local Time:
          4:26 AM
          Rebuild the stock suspension, equip it with shocks,torsion bars and a sway bar matched to your tastes, add Street type Wilwood disc brakes, and you will be happy and can have a 4.5 bolt circle to boot!
        • jw97neon
          jw97neon Well-Known Member
          271
          75
          Sep 10, 2013
          utah
          Local Time:
          10:26 PM
          this is my 65 dart. i went this way to get rid of my torsion bars. i was unable to pass up the price. i was going to with a rack setup but felt this would. if you are interested in something like this contact hemi denny.
        • Dennis Richardson
          15
          1
          Apr 24, 2017
          Illinois
          Local Time:
          11:26 PM
          That's pretty nice. Like the stance. What's the price tag on a set up like that.
        • Dennis Richardson
          15
          1
          Apr 24, 2017
          Illinois
          Local Time:
          11:26 PM
          In need of 65 taillights if you know anybody place thats got good ones.
        • jw97neon
          271
          75
          Sep 10, 2013
          utah
          Local Time:
          10:26 PM
          i am probably 1500 into my setup. not sure what hemi denny charges. he is only one making a kit.
        • 1968Dart
          1968Dart My 63 Dart 2 door Sedan
          50
          3
          Jun 9, 2009
          Ontario, Canada
          Local Time:
          10:26 PM
          Hi, I was wondering how you like this kit? I'm thinking of getting it for my 63 Dart. Did it come with the coils or did you have to buy extra?
          Thanks
        • pishta
          pishta I know I'm right....
          13,906
          3612
          Oct 13, 2004
          Tustin, CA
          Local Time:
          9:26 PM
          What lights: bezels or lenses? stiffer torsion bars help. sub frame connectors really help.
        • 65dartcharger
          65dartcharger FABO Gold Member FABO Gold Member
          6,320
          853
          Dec 9, 2006
          Tavelsjo, Sweden
          Local Time:
          5:26 AM
          Awesome look!
          • Like Like x 1
          • jw97neon
            271
            75
            Sep 10, 2013
            utah
            Local Time:
            10:26 PM
            . this kit did come with the coils. i have yet to drive mine more then 10 ft. so as far as ride still up in the air. i feel as if there will be no problems. talk to hemi denny. he is the only one making these kits. super nice guy and very knowledgeable.
          • dart4forte
            dart4forte FABO Gold Member FABO Gold Member
            4,157
            570
            May 28, 2004
            Mesa, AZ
            Local Time:
            4:26 AM
            Lets see some more of this car
            • Like Like x 1
            • jw97neon
              271
              75
              Sep 10, 2013
              utah
              Local Time:
              10:26 PM
              . thank you . it is not much. as i am working on swapping the rear axle out. but here is a idea of what it will look like when finished.
            • dart4forte
              4,157
              570
              May 28, 2004
              Mesa, AZ
              Local Time:
              4:26 AM
            • jw97neon
              271
              75
              Sep 10, 2013
              utah
              Local Time:
              10:26 PM
              17x7 and 17x8
            • dart4forte
              4,157
              570
              May 28, 2004
              Mesa, AZ
              Local Time:
              4:26 AM
              That has a nice stance. I like the wheels you have except I like the gray centers
              • Like Like x 1
