65 positive battery cable
Electrical and Ignition
  1. ragtopfury
    ragtopfury FABO Gold Member FABO Gold Member
    2,275
    1177
    Jul 14, 2011
    Baltimore area
    Local Time:
    5:17 PM
    So where is the best place to get a new original type positive battery cable ? 65 Barracuda.
  2. pishta
    pishta I know I'm right....
    14,242
    3909
    Oct 13, 2004
    Tustin, CA
    Local Time:
    2:17 PM
    That one seems a rare bird for some reason. IIRC , it had a smaller gauge tap off the side for something? You see the negatives everywhere. let us know if you find a source thats under $100!
  3. toolmanmike
    toolmanmike FABO Staff Staff Member FABO Gold Member
    37,765
    20075
    Jan 18, 2006
    Iowa
    Local Time:
    4:17 PM
  4. pishta
    14,242
    3909
    Oct 13, 2004
    Tustin, CA
    Local Time:
    2:17 PM
  5. toolmanmike
    37,765
    20075
    Jan 18, 2006
    Iowa
    Local Time:
    4:17 PM
  6. ragtopfury
    2,275
    1177
    Jul 14, 2011
    Baltimore area
    Local Time:
    5:17 PM
  7. C130 Chief
    C130 Chief Mechanical Genius
    2,982
    134
    Nov 23, 2005
    Boise, ID
    Local Time:
    3:17 PM
    Does it need to look like the original 65 V-8 cable, or just start the car?
  8. ragtopfury
    2,275
    1177
    Jul 14, 2011
    Baltimore area
    Local Time:
    5:17 PM
    Option 2. The car is not at original car anyway so we can do it neatly and make it work
  9. pishta
    14,242
    3909
    Oct 13, 2004
    Tustin, CA
    Local Time:
    2:17 PM
    its very different: It has 4 taps and a splice. I think maybe the taps are not taps at all but just siamese cables under 1 sheath? Mine is so far gone from stock that its not applicable.
  10. prorac1
    prorac1 Well-Known Member
    1,456
    1265
    Sep 29, 2012
    Martin, Mi
    Local Time:
    5:17 PM
    The extra lead from the factory cable fed power to the starter relay.
    I believe the factory "crank" wire ran back towards the battery and along the cable to the starter.
    It looks more like an entire harness from pictures I've seen than just a cable.
    We're making an aftermarket cable look factory-ish. Lol
    Hope this helps
  11. ragtopfury
    2,275
    1177
    Jul 14, 2011
    Baltimore area
    Local Time:
    5:17 PM
    Yes. This is a much simpler look at how it's hooked up. And pretty much what he is going to do. There was really nothing too special about the original that we can't do ourselves and make it look presentable.
