[FOR SALE] 65 Valiant
Ramzc36
Member
Indianapolis
Rating - 0%
0   0   0
Roller Parts Car located in Indianapolis
Details...???
What would you like to know? Is a 65 signet. Currently a roller. Pulled engine and transmission to put in my 64 Dart and swapped rear ends. Rear end is a 7 1/4 out of a 64 Dart GT. Missing the sun visors and rear view mirror as those also went to the dart but other than that it is original. I have the visors and mirror that can go back with it just stole them as mine are a little rough.
OK, gotcha, looking to keep it together....good luck with the sale!
Jim K6
Any chance it has a factory rear defroster blower motor with vent, wiring, and dash switch?
Thank you. It won't have the small part I need since it is an automatic car. Good luck with the sale.
:thumbsup:
What do you need? I may have it. Family is big moose collectors and we have quite a bit of slant 6 pieces. I have a whole other twin to this valiant.
I need the plate from the bottom of the steering column. It holds the steering column to the firewall. It would have to be from a straight drive 65 Valiant or Barracuda. I have 2 from automatic cars, but I am converting my 65 Barracuda to a 4 speed. They are different from an automatic plate, because the clutch rod goes thru the plate, which will have an oval hole beside the big round hole for the column. Doesn't matter if it's a V8 car or a slant, as long as it is a straight drive.
Let me check this weekend and see what’s in the other car I’ll get back to you.
I apologize I thought I replied to this. Have a 65 valiant that was factory 4 speed with this plate if you haven’t found it yet. Just needs to dry out so I can get outside and get it
No problem at all. :) Just let me know when you get to it. Look close at it, because you may be able to get it out without completely removing the column. It has a slot in one side, so you may be able to loosen the column up real good and slide it out.
:thumbsup:
:thumbsup:
I will. It just sits outside at my grandparents an hour and a half away.
