66 273 Barr oil pan removal?
No sir, I do believe you have to lift the engine to get it around the center link and K-frame. Are you rebuilding your entire motor?? I was watching your other thread for updates as I am facing the same situation as you. Geof
It has been quite a few beers ago but I think I did mine just by dropping the centerlink and not jacking the motor.
I had a small oil leak so thought I might as well do the the oil pan while I had everything else off. Then I figured if I had the pan off might as well do the pump too. It never ends...........
