[WANTED] 66 and earlier 273 motor mounts
There’s a 65 Dart 270 with a 273 in it at the yard I was at the other day. I hope to pull the motor mounts and anything else of valve when I go back when it’s cooler.
I have a set that are all nice and greezy, well preserved you could say. I do need to remove the old mounts. Bolts included, that is if you need them!
If all you want is the mount biscuit, they are available pretty much anywhere. Lolita on the street corner might have a set and give you a happy ending.
