66 Barracuda Hood Buffeting at 70+ mph
Mopar Body and Trim
  1. 66fyssh
    66fyssh Don't Stop Believin' FABO Gold Member
    5,357
    4403
    Jun 22, 2013
    Northwest GA
    Local Time:
    9:10 PM
    My hood starts buffeting about 70 mph. Is that normal for a 54 year old car? I'd like to find a way to keep it still at speeds.
    The center latch has maybe 1/16" play.
    I can raise the front corner hood bumpers but then the hood is above the fenders.
    Anybody have any suggestions??
  2. rustycowll69
    rustycowll69 Well-Known Member
    2,230
    1028
    Feb 19, 2016
    Pacific northwest
    Local Time:
    6:10 PM
    is it just the skin buffetting? Maybe you can "reglue" the skin underside to the hood frame.
  3. 66fyssh
    5,357
    4403
    Jun 22, 2013
    Northwest GA
    Local Time:
    9:10 PM
    I think it's the entire hood but only on the sides near the fenders. The hood feels solid.
  4. rustycowll69
    2,230
    1028
    Feb 19, 2016
    Pacific northwest
    Local Time:
    6:10 PM
    I haven't looked at my hood for years, but on some years they have rubber bumpers along the fender edges which firm up that top of fender to hood gap.
    • Thanks! Thanks! x 1
    • 66fyssh
      5,357
      4403
      Jun 22, 2013
      Northwest GA
      Local Time:
      9:10 PM
      I have those. I tried raising them but it raises the hood above the fenders. I'll try it again and take a drive to see if it helps.
    • SpikeWills69
      SpikeWills69 Too Soon Old, Too Late Smart
      1,598
      136
      Apr 7, 2010
      Near ZMax Dragway
      Local Time:
      9:10 PM
      Just curious, could there be extra air sneaking in under the hood somehow? I had a 66, but it's been too long. Do they have an air dam under the radiator support or anything like that? Splash guards all in place, if they exist?
    • 1969383S
      1969383S FABO Gold Member FABO Gold Member
      5,661
      2662
      Jan 8, 2012
      Cumming, GA.
      Local Time:
      9:10 PM
      These are what he was referring to. Are they present on a 66?
      they line up with the indentions on the hood to help center and support.
    • 1969383S
      5,661
      2662
      Jan 8, 2012
      Cumming, GA.
      Local Time:
      9:10 PM
      And what about the rear seal at the cowl? Obviously your front seal is in tact!
    • 66fyssh
      5,357
      4403
      Jun 22, 2013
      Northwest GA
      Local Time:
      9:10 PM
      I appreciate the suggestions!
      All splash guards are in place. I do see on the hood to radiator seal there is a gap towards each side. All clips are in and I remember buying the seal for a 66. I may see how I can secure it down tight in those areas.
      Gerald, the 66 has those side bumpers but they are much further back. And it got a new cowl seal about 7 years ago.
      I don't get a lot of movement of the hood, but it's more than I like at speed.
    • 1969383S
      5,661
      2662
      Jan 8, 2012
      Cumming, GA.
      Local Time:
      9:10 PM
      Try going faster!:lol:
      • Like Like x 1
      • Agree Agree x 1
      • Syleng1
        Syleng1 Karma is real and Life is short... FABO Gold Member
        1,641
        1198
        Jul 5, 2005
        North Franklin, CT
        Local Time:
        9:10 PM
        On my 66 cuda- my hood pops up a bit at high speed. I tried to raise the bumpers but it put the hood above the fenders.
        finally I dropped the hood latch (2@ 1/2” bolts) it pulls down the hood enough to be tight but not tight enough not to latch.
        • Like Like x 1
        • Agree Agree x 1
        • 66fyssh
          5,357
          4403
          Jun 22, 2013
          Northwest GA
          Local Time:
          9:10 PM
          Here are some pictures.
          The gap in the seal.
          Anyone know what this hole is for?
          Here's the bumper in the back.
        • 66fyssh
          5,357
          4403
          Jun 22, 2013
          Northwest GA
          Local Time:
          9:10 PM
          Thanks! I'll adjust that tomorrow. I may raise the bumpers just a hair too.
        • 66fyssh
          5,357
          4403
          Jun 22, 2013
          Northwest GA
          Local Time:
          9:10 PM
          Like an airplane! Once you get past a certain speed, it smooths out!
        • 1969383S
          5,661
          2662
          Jan 8, 2012
          Cumming, GA.
          Local Time:
          9:10 PM
          Thanks for replying.
          Just realized the air conditioning was still on in the garage by seeing that picture again and about to go to bed!
          Your front seal looks a bit weird. Only one block per side on 66?
        • 66fyssh
          5,357
          4403
          Jun 22, 2013
          Northwest GA
          Local Time:
          9:10 PM
          Sucks getting old and forgetting stuff, lol.
          Yes, only one block per side. I'll research to see if that's correct, but there's only one slot for them.
        • 66fyssh
          5,357
          4403
          Jun 22, 2013
          Northwest GA
          Local Time:
          9:10 PM
          I hadn't thought about it before, but looking at the way it lays, I'm going to check out the seal also.
        • Kendog 170
          Kendog 170 Let the boy go !
          1,112
          700
          Mar 10, 2016
          Tewksbury Ma.
          Local Time:
          9:10 PM
          Adjust your hood latch mechanizm down (It's adjustable.). My car was doing that too. Set your hood stops so hood is flush with the fenders then lower the latch down evenly. I have to really let the hood close with some extra force but I have zero shake on hyway. JMO
          • Agree Agree x 1
          • 66jim
            66jim Well-Known Member
            483
            459
            Dec 11, 2007
            NE PA ie pennsyltucky
            Local Time:
            9:10 PM
            Check the grill stiffening bracket below the hood latch my 66 was doing the exact same an the bracket was cracked. Sorry no picture, if cracked will allow hood to move
            like that. Just gave the bracket a zap with the Mig while still in place all good.
            • 66fyssh
              5,357
              4403
              Jun 22, 2013
              Northwest GA
              Local Time:
              9:10 PM
              Thanks all. Sounds like the fix is going to be the latch. I'll get out there today and check out the latch and stiffening plate, and adjust the latch down.
            • Kendog 170
              1,112
              700
              Mar 10, 2016
              Tewksbury Ma.
              Local Time:
              9:10 PM
              Let us know what you find.
            • 66fyssh
              5,357
              4403
              Jun 22, 2013
              Northwest GA
              Local Time:
              9:10 PM
              I'll let you know. I definitely want to reduce the amount of it.
            • ZooKypr
              ZooKypr Well-Known Member
              1,788
              156
              Jul 5, 2009
              NJ
              Local Time:
              9:10 PM
              Any lifting in the rear of the hood near the firewall? If everything checks out listed above. Its a long shot but check your hood hinges.
            • 66fyssh
              5,357
              4403
              Jun 22, 2013
              Northwest GA
              Local Time:
              9:10 PM
              Thanks @ZooKypr . The back of the hood is good and tight. Just both sides of the front start bouncing up and down starting at about 70 mph. I'm going to have a good look at the latch area and adjust it down to get rid all the play.
              • Like Like x 1
              • pishta
                pishta I know I'm right....
                17,648
                7222
                Oct 13, 2004
                Tustin, CA
                Local Time:
                6:10 PM
                Damn, those early hoods are heavy and stiff, hope you get it sorted out and let us know what the issue was.
                • Like Like x 1
