Budget mopar guy
So for those of you not familiar with my car I have a 66 cuda gasser project 4 speed that I’m putting a 5.9 magnum in. I’d like to break into the 10s even if it’s high 10s. My goal is to figure out power wise what I’m going to need to do to get it into the 10s. It needs to be noted that it is an early magnum (96) so it is drilled for LA HEADS so I will be running an La top end.
So far I have the short block I will be freshening up. Promaxx cnc ported heads. No intake yet but I had considered a tunnel Ram because ….. well gasser. I think I’m going to get a custom grind cam. No idea on specs yet. The car itself should be really light. It will have a roll bar legal to 10.5 but nothing in the way of interior other than seats and dash. Fiberglass hood will be a must. I cant say for sure what the weight will be but I’d imagine this car should be pretty light in my opinion.
I understand that gear and driver and whatnot plays into what the car will run. Let’s assume that all that is optimal. What kind of power do I need to make to hit 10.9/10.8. Ive seen multiple very simple 360 builds online with just 10.5 pistons and stock eddy heads putting out 420 up. I’ve also seen fully dressed street cars with stock bottom ends and eq heads run a high 11. My question is what will it take. Is this even possible with a stock piston . And n20 100 shot is not out of the question if necessary but ideally I’d like to make it all motor. The way I see it is the odds are kinda stacked against the setup but then again the car should be pretty darn light so I’m not sure. Any setups out there that are 360 that have accomplished this goal? Any info / guidance is appreciated
