TT5.9mag
Two atmospheres are better than one
With a 6300 converter and a 4.86:1 gear a monkey on a tricycle could go 10s.here is my 355''. this is a good example of what it takes.
Here's the engine in his Camaro "HeadHunter". I don't know WHAT it is and nobody else does either. It's not slow. I'm not sure Mark even drives it anymore. He had a really BAD bike wreck several years ago and broke his back and lots of other bones. Almost killed him. He had to learn to walk all over again and he's still not right. I don't know how much he can do sitting down so I THINK he lets another friend drive it now.A lot. I’m going to ask mine to make north of 900.
But COULD he hold on?With a 6300 converter and a 4.86:1 gear a monkey on a tricycle could go 10s.
...and it wasn't an idiot question. How do you know if you don't ask? ...and I'm not talkin about the OP here but a lot of these cats sayin "I want 700HP" and such have never driven a well prepped car with an honest 350HP. You can get jiggy with that kinda power in a well prepped A body.Nope, the OP. 65
*three raccoons have entered the chat*With a 6300 converter and a 4.86:1 gear a monkey on a tricycle could go 10s.
LS based with a big ole snail.Here's the engine in his Camaro "HeadHunter". I don't know WHAT it is and nobody else does either. It's not slow. I'm not sure Mark even drives it anymore. He had a really BAD bike wreck several years ago and broke his back and lots of other bones. Almost killed him. He had to learn to walk all over again and he's still not right. I don't know how much he can do sitting down so I THINK he lets another friend drive it now.
Not sure if that question was meant to be a jerk and question my ability or not but yes I have driven low 10 second cars before and my dart runs low 11s consistently . What is your point exactly? Let’s clear that up.Not to be an idiot, but, have you ever driven a mid 10's car? 65
only the scale will tell. Maybe I should just put an LS in it lol. Forget all the old school mopar small block stuff that apparently doesn’t make very good power for the cost in all realityBudget Mopar guy, if you are gonna use a stick, in MY opinion, you just made your job exponentially more difficult.... and less budget friendly.
It will probably be a lot of fun as long as you don't break stuff
I ran a 406, good for about 500 hp, in a very light car, with a glide and a brake. I left at full throttle, max stall, so similar (kinda) shock loading to a stick.
I had a 4" shaft, with billet yokes and 1350 joints on both ends, a nine inch with a nodular center, spool, 33 spline strange axles, and 14"slicks/4.57 gears.
In a heavier car (maybe just a little bit in your case) with a stick, you will likely need a similar level of driveline beef, probably starting with a dana 60.
Low budget, it's probably not.
No offense, but I think 2500 lbs for your car is optimistic.
Well I KNOW that. lolLS based with a big ole snail.
I didn't get that vibe at all. We don't know if we don't ask. Maybe if we had one of these...Not sure if that question was meant to be a jerk and question my ability or not but yes I have driven low 10 second cars before and my dart runs low 11s consistently . What is your point exactly? Let’s clear that up.
What does someone’s driving ability have to do to do with minimum hp numbers on known high 10 second combos? As the thread was askingI didn't get that vibe at all. We don't know if we don't ask. Maybe if we had one of these...
I know this was directed at Rusty, but, it has everything to do with it. You can take a well sorted high ten combo, put some schmuck behind the wheel and i guarantee it will not run the number. If they don't know the burnout routine, the shift points, where or what temp the engine needs...... Lot of variables that takes time to sort out. Most of the time, the driver and car builder are one in the same. They truly "know" the car.What does someone’s driving ability have to do to do with minimum hp numbers on known high 10 second combos? As the thread was asking
It's called a discussion for a reason. I didn't see you lay down any ground rules. It was a legitimate question. As I said, don't know if you don't ask. If you don't want help here, just say the word.What does someone’s driving ability have to do to do with minimum hp numbers on known high 10 second combos? As the thread was asking
Oh and he didn't ask about your ABILITY. He asked if you had been that fast or quick. Simple question.What does someone’s driving ability have to do to do with minimum hp numbers on known high 10 second combos? As the thread was asking
Agree! Especially with a stick car. It takes familiarity and skill with any stick car to get the most out of it.I know this was directed at Rusty, but, it has everything to do with it. You can take a well sorted high ten combo, put some schmuck behind the wheel and i guarantee it will not run the number. If they don't know the burnout routine, the shift points, where or what temp the engine needs...... Lot of variables that takes time to sort out. Most of the time, the driver and car builder are one in the same. They truly "know" the car.
At the point the question was asked, we didn't know you had a low 11s dart.Oh and he didn't ask about your ABILITY. He asked if you had been that fast or quick. Simple question.
Did we "know" he had anything?At the point the question was asked, we didn't know you had a low 11s dart.
Just asking, not trying to offend anyone. Personally, I have not driven a car that fast. If you have, you should have a good idea of what it takes. Especially, with a car built from ground up. There should be certain steps to take in order to achieve your goals. Sorting out a car could/should take multiple T&T at the track. JMO/JME. 65Not sure if that question was meant to be a jerk and question my ability or not but yes I have driven low 10 second cars before and my dart runs low 11s consistently . What is your point exactly? Let’s clear that up.
