There seams to be a stigma about installing glass. I have broken my share of split windshields but one piece windshields are a lot easier to work with. The early Baracuda rear glass is tough as nails because of the shape and thickness. They aren't that hard to find for this reason. They just don't usually break. I've seen them on eBay for under $200. As for removing and installing the rear window, I paid $135 to have a glass shop remove my windshield. When I saw how easy it is, I installed it by myself and saved the $135 to install it. When I had the headliner installed, I removed and installed both the windshield and backlight by myself with no help and I'm no superman. However, a helper is a good idea. Here's how its done:
Lay a blanket or someting soft on the cowl and hood. Remove the interior trim and lock strip, at the upper corners of the glass, firmly push outward. The glass should come out at the corners and gently lay the glass on the hood. The rear glass should come out the same way and can be laid on the roof. Make sure the edges of the opening are clean before installing. My glass shop doesn't use silicone or sealer, so I don't either. Upon re-installing, using small strips of tape to hold the gasket in place around the opening. Starting at the bottom, lay the glass in place in the gasket and work it around into the grove. A little soapy water may help the glass slide into the gasket. Installing the lock strip should take care of any gap in the seal. Good luck.
