67 273 Commando Valve Cover Breather Cap & PCV Valve
Bossanova5
Los Angeles
Does anyone know the part numbers or where to buy the breather cap and pcv valve cap and rubber grommet assembly that fits the 67 273 Commando Valve Covers?
Thanks
I'm 99% sure that the breather for 67 commando is a chromed version of the stock black breather with (CAP) or without the tube
the 67 pcv valve uses a rubber grommet that goes into the valve cover hole.
The 66 and older uses a cap like a breather cap with a hole and the pcv goes into that
The pcv valve itself is the same 67 and older.
The cap with the pcv in it is 66 and older.
Here is good info
65 Commando VS 67 Commando
