Hi all, here is a header panel I removed from 68 cuda. It will work for 67 as well but letter location and spacing is different.
Has partial grille pieces still attached. Pass side is mostly complete but pretty sure studs will break if I try to remove the nuts. Header looks solid but does need some straightening.
$125 + the ride from Peterborough Ontario
Will ship but it won' be cheap.
Thanks
Steve
Thanks
Steve
