This is every thing you need to put a windage tray and pan on a 340. The pan is a factory 384 pan and has no road rash at all it is perfect.
. Everything is clean and ready to install.
You get
1. perfect early 273,318. 340 #384 Oil pan stripped to bare metal and self etch primed
16. 5/16-18 factory pan to block bolts
2. 5/16-18 pan to timing cover bolts
4. 1/2-13 340 main cap bolts for the windage tray
4. 1/4-20 factory windage tray to main cap bolts
1. factory oil pan plug
1 factory oil pickup sonic cleaned
All parts are clean and ready to use. Pick up tube was sonic cleaned
I am asking $300 shipped to the lower 48 for everything.
You can make an offer
The parts are in Danielsville Pa. and can be picked up in person for $250
I have the same thing for 70-72 I will clean up at a later date.
You get
