67-69 barracuda 4 speed parts fit 70-72 dart/valiant?
Manual Transmission & Clutch Discussions
  1. 1972scamp
    1972scamp Active Member
    27
    0
    Aug 19, 2011
    Mentone, CA
    Local Time:
    8:59 AM
    Hey guys, I've tried doing some research but haven't found much. I am curious if anyone knows if a 4 speed setup (less pedals & steering column) will fit into my 72 scamp. The floor hump looks like it will work, but what about everything else? The setup is said to be from a v8 (small block) car. Any insight would be much appreciated.
  2. mopardude318
    mopardude318 Well-Known Member
    10,095
    1364
    Jan 7, 2005
    Gilroy, Ca
    Local Time:
    6:59 AM
    yes, it will all fit, and work just fine.
  3. 66340SEDAN
    66340SEDAN FABO Member #3649
    29,412
    39752
    Nov 20, 2006
    Minnesota
    Local Time:
    8:59 AM
    x2
  4. crackedback
    crackedback FABO Gold Member FABO Gold Member
    18,885
    3312
    Aug 7, 2005
    92201
    Local Time:
    6:59 AM
    67-69 stuff won't have a clutch safety switch on it, but it will physically bolt in.
  5. 1972scamp
    27
    0
    Aug 19, 2011
    Mentone, CA
    Local Time:
    8:59 AM
    Awesome, thanks guys. I think I can live without a safety switch :glasses7:
  6. RedFish
    RedFish Well-Known Member
    24,908
    3299
    Sep 5, 2007
    Local Time:
    8:59 AM
    I can only suggest you find out exactly what the origin was. I talked with a guy who bought a 71 Duster and found the 4 speed trans installed by previous owner came from a 1st gen' / pre 67 A-body.
    Small differences at pilot shaft and bushing, speedometer cable, etc.., made for a few small headaches.
    Good luck
  7. DaveBonds
    DaveBonds Garage Trash
    2,205
    38
    Feb 11, 2013
    Lakewood, CO
    Local Time:
    7:59 AM
    Do it.
    Vin on the trans case tells a story.
    For what it's worth, I'm building a transmission out of parts from about six different vehicles.
    Case from a b body, gear set and input from a late model truck, F body main shaft, Shifter from a B body, shift mount and tailshaft from an A body and a bellhousing from an E body, pedals and floor from a late A body.
    Most of this stuff is the same.
