67-69 column differences?
Suspension, Steering and Chassis
  1. hosehead
    hosehead Well-Known Member
    1,183
    976
    Dec 4, 2008
    Grand Lake o the Cherokees
    Local Time:
    5:19 AM
    Hey all, I purchased a 67 barracuda that has some missing parts. I need a column. I am going to look at a column owned by a gentleman who isn't sure of the year.
    I know what the early a columns look like and what the 70 and up look like.
    Is there any difference I need to know between 67-69? I have heard 67 is a unique year.
    And it is a manual steering, floor shift if that makes any difference.
    Thanks for listening guys.
  2. 4spdragtop
    4spdragtop CONGRATS NORTH AMERICA! FABO Gold Member
    32,902
    14166
    Aug 28, 2009
    Wasting time here
    Local Time:
    7:19 AM
    Corey, I have a 67 floor shift column at home if you want pics.
    **edit** I believe 67 column is "1 year only" but no reason why you couldnt use a 68/9 as well.
    • Thanks! Thanks! x 1
    • Agree Agree x 1
    • 4spdragtop
      32,902
      14166
      Aug 28, 2009
      Wasting time here
      Local Time:
      7:19 AM
      Heres a 67 column. Sorry not the greatest pics. I can take more of specific areas if need be.
      • mcodecuda
        mcodecuda Senior Member
        803
        358
        Sep 17, 2007
        Sherrills Ford NC
        Local Time:
        8:19 AM
        Don’t quote me on this but sometime around 67 the neutral safety or back up switch was moved to the column. This was before they were combined together on the transmission. Of course no NSS with manual transmissions.
        • Murray
          Murray FABO Gold Member FABO Gold Member
          2,668
          1956
          Apr 19, 2010
          San Jose, California
          Local Time:
          5:19 AM
          Main difference to look for- is your car a floor shift (4-sp or auto) or a column shift? Is it P/S or manual steering ( different length).
          • clementine
            clementine Flight risk FABO Gold Member
            1,985
            1430
            Jan 3, 2016
            Emerald city
            Local Time:
            5:19 AM
            tube diameter is larger on a 67 IIRC. So the flange on the floor is different. I havent finished mine but I think that will make the lower bearing different too. Maybe someone can confirm or deny this info.
            • hosehead
              1,183
              976
              Dec 4, 2008
              Local Time:
              5:19 AM
              As stated earlier. It’s a manual trans, manual steering, floor shift car. So maybe it doesn’t matter? It’s not a resto, just gonna be a driver.
              I’d like it to look correct of course.
              Thanks for the responses so far guys. I really appreciate it!
              • Like Like x 1
              • matthon
                matthon Well-Known Member
                2,550
                718
                Aug 29, 2008
                Local Time:
                8:19 AM
                67, the inner shaft tube is a different diameter, and the lower plastic bearing is a different piece of garbage, (from 1 source only, and you have to email them, pay big $).
                You can get the lower steel ball bearing 'kit' to rebuild that, which is ridiculous, who wants to rebuild a bearing instead of buying one.
                And don't believe the hype, finding a bearing to replace the plastic/steel lower bearing is not possible, at least one that fits correctly.
                Finding a manual shift column is another task in itself.
                In my case, the spent lower bearing destroyed the lower inner column, and a replacement inner column was half the price of a completely rebuilt 68 column from Norm's.
                I went with Norm's and it is perfect.
                Flange is the same, 67 to 68 at least.
                67 Steering Column - Help
