67-69 cuda fender differences?
mopardude318
Gilroy, Ca
hello. I need a fender for my 68 cuda...I found a 69 parts car...it has nice fenders for 200 each...i know the side marker hole is rectangle on 69. what else is different? does everything else change over easily? will i have problems with the '68 headlight assembly and front trim going into the '69 fender headlight bucket? Ideally, I want everything to bolt right in...I need to know ALL the differences before I buy so i know what I'm getting into...
thnaks for you time and help.
-James
Other than the large rectangle for the reflector I'm thinking the fish emblem is longer on a 69 than a 67 or 68. I may be wrong so check it.
Some emblems and mounting holes are different , I think grille mounts different .
68 fender has same dimensions, attachment points
I am doing the same thing for my 67.67-68 fenders are the same except for the hole for the marker light.69 has two tabs on the headlight bucket that you have to cut off.You know the rest. Mark
