[SOLD] 67-69 SB Saginaw power steering pump parts minus the pump itself
physixx
Edison, NJ
I have for sake a used 67-69 SB Saginaw power steering pump parts kit. Everything but the pump itself. The pump was partially seized from sitting in a shed for a while so is now in the scarp pile. Included is the reservoir, the 2 mounting brackets and all the nuts and bolts to mount it, the pump pulley measuring 6 ¼”, attaching nut and keyway to mount to the pump shaft. All that is needed is the pump itself. Again, this is for the early 67-69 SB engines using the cast iron water pump. All the parts are clean and painted and the pump reservoir is fairly dent free and comes with the filler cap. A couple of small dents is all. I would like to get $30.00 for everything plus the shipping. All the parts fit into the USPS medium flat rate box for $17.10 and will get to any of the 50 States.
Ken
Edison, NJ
