[SOLD] 67-72 A body bucket seat tracks.
moparmat2000
Grand Tetons
67-72 A body bucket seat tracks. Needs some work. 1 assist spring missing, one broken stud. Both easily remedied. Small spot of heavy corrosion that can be easily cut out and new metal welded in. Appears to be just rotted thru by carriage bolt hole in track. What you see is what you get. $260 plus shipping. I can weld in a new stud for some extra dollars. Located in west Texas. I accept paypal.
Hi, Am I wrong in thinking that the 1968-69 seat tracks taper from front to back on the drivers side seat track due to the difference in the height of the floor pan ?, sorry if I have my facts wrong, thanks.
I have a 67 notch and a 69 notch both stripped down to do restoration. Same floorpan both cars. AMD even lists the floor pan as all A body 108" wheelbase 67-72. Stamping changes in 1973 but its just positioning or elimination of reinforcing ribs.
Same floorpan under the 110" wheelbase cars like darts. Except *** end of the pan is longer by 2 inches. How do i know the differences? I used a 74 dart 4 door rust free man in my 67 barracuda. Fit just fine. Cut it 2 inches short at the back and put 1 non stock seam in it.
I have used this style track to also mount 73-76 buckets ..to mount 70-76 buckets the studs have to be cut off upper rails of the tracks and a hole drilled right beside where stud was cut eigth inch inwards..bottom studs fit in floor without mods.
