gregpurcell
Greg Purcell
This is the driver's side fresh air vent from a 67 Dodge Dart. It has the little door that opens
to let in air. As you know, the hinges tend to rust and lock up the door. This one was repaired. The hinge rivets were drilled off, the door hinge was wire wheeled, painted and lubed and the door was replaced to the plastic body using screws and nuts (do not show when installed with door closed).
This part could use a bit more cleaning but it is in good overall condition. Located in Savannah, GA $35 shipped
