on a 67 barracuda i am using the 73 340 manifold my question is it possible to have 2.25in pipes fit through the starter and torsion bar? wanted to have 2.25 from the exhaust manifolds all the way back. i also have a mini starter, the motor is a 318.
TTI makes a 2.5" headpipe for that. The 73 drivers upward horn hipo manifold has the same outlet diameter and head port geometry as a 340 '68-'71 hipo drivers manifold. Problem is the passenger side 71-73 340 manifold is log type and smaller outlet diameter.
yes for the passenger side i used the jeep grand cherokee exhaust manifold exit hole it 2 1/8. its cause the muffler guy i go to said, he cant make the driver side 2.25 he would have to start at 1 3/4inch then to 2inch then to 2.25 like the rest of my exhaust system . and i said yeahhhhhhhhhh ill do some research lol ill be back
top>TTI> Swinger 4-speed middle >home made Swinger > auto bottom > TTI E-body > auto or (last pic) > left to right > 4 speed > homemade > e-body
Tti has 2.25 diameter cause My exhaust is 2.25 to the back. And the other side is not a 340 manifold so there package deal would only work on one side.
Does anyone other than TTi make the mid exhaust pipe? That's the pipe from the 340 exhaust manifolds back connecting to the 2 1/2" Pypes exhaust system.
