Shmaako
Changing to a 73 lbp disc brakes instead of buying sbp disc setup to avoid obsolete and hard to find parts and rims. (However, it means I also have to replace my sbp axles in the back as well as purchase new rims.)
I now have the LCA from the 73 with sway bar tabs.
Wondering if I can buy a sway bar that mounts to LCA tabs but does not go through the k member as the donor car had.
Also, my car had a power steering box just not hooked up and no power steering pump at all on the existing 383. I intend to upgrade to larger torsion bars as the existing are smaller factory ones not intended for this big block. Wondering if I'm headed for trouble with regards to how it all fits and rubbing issues etc.
I'm assuming I will be ordering steering parts (tie rod ends, strut rods, pitman, idler, etc)for a 67 and upper and lower ball joints and uca bushings for a 73? Regular 73 upper ball joint? or offset?
