67 Barracuda, which wiper and switch do I have?
Electrical and Ignition
  1. ChuckDock
    ChuckDock Well-Known Member
    138
    54
    Jan 7, 2018
    Goodrich, MI
    Local Time:
    11:37 PM
    Trying to get wipers working. Here is a pic of the switch and motor. Are they a proper pair?
    The switch has a resistor and so does the wiper motor. It that a correct match?
  2. mvh
    mvh FABO Gold Member FABO Gold Member
    1,391
    169
    Dec 17, 2007
    Menlo Park, CA
    Local Time:
    8:37 PM
    That looks like my 2-speed wiper motor and switch. But I'm not that familiar with the 3-speed version to compare.
  3. Frnknsteen
    Frnknsteen FABO Gold Member FABO Gold Member
    542
    315
    May 26, 2011
    Spencer, IN
    Local Time:
    11:37 PM
    That is a 2spd motor, and looks like my 2spd switch, but I can't say for sure on the switch.
  4. ChuckDock
    138
    54
    Jan 7, 2018
    Goodrich, MI
    Local Time:
    11:37 PM
    Does your switch does have the white rectangular resistor on it?
  5. Frnknsteen
    542
    315
    May 26, 2011
    Spencer, IN
    Local Time:
    11:37 PM
    I did a quick search and none of the 2spd switches I saw had the resister on it. On the pictures I saw, the only ones with resisters were the 3spd switches.
    Click the switch through its ranges to see how many positions there are. If there are 3 positions, it should be a 2 spd (off, Low, and High). If it has 4 positions, it should be a 3spd switch (Off, Low, Middle, & High).
  6. ChuckDock
    138
    54
    Jan 7, 2018
    Goodrich, MI
    Local Time:
    11:37 PM
    I did that and it clicks like a 2 speed. Off, click 1, click 2.
    I see the same as you, I see the typical 2 speed switches with no resistor built into them. The connector under the dash seems original to and my resistor switch connects correctly.
    I looked on this forum about how to test the motor. I would think just putting 12 volts to it, and make sure it has ground and it should spin if it works. I probably need to pull it out and wire it up with the switch though, and just make it work there them re-install it.
  7. 4spdragtop
    4spdragtop FABO Gold Member FABO Gold Member
    25,423
    4859
    Aug 28, 2009
    Ontario
    Local Time:
    10:37 PM
    That is a 3 spd wiper. They lay "flat/parallel" with firewall.
    2spds stick or point out. I dont see a resistor on your motor.
    Part #'s on switch?
  8. Frnknsteen
    542
    315
    May 26, 2011
    Spencer, IN
    Local Time:
    11:37 PM
    Not in 1967. The pre-68 2spd wiper motors sit parallel to the fire wall like that. I was confused by that too when I first bought my '67. That is a 1967 2spd wiper motor. Here is mine.
  9. 4spdragtop
    25,423
    4859
    Aug 28, 2009
    Ontario
    Local Time:
    10:37 PM
    Cool, it looks like 67 2spd could be both ways? I had a 2spd from 67 that pointed out. Mine is a 67 3spd and plays flat.
  10. ChuckDock
    138
    54
    Jan 7, 2018
    Goodrich, MI
    Local Time:
    11:37 PM
    Ok, guess that means my motor and switch line up. Itake it your switch does not have the white resistor. I wonder what the resistor is about if the motor assemble already has the resistor built in.
  11. 4spdragtop
    25,423
    4859
    Aug 28, 2009
    Ontario
    Local Time:
    10:37 PM
    Our 67 3spd.
  12. ChuckDock
    138
    54
    Jan 7, 2018
    Goodrich, MI
    Local Time:
    11:37 PM
    #2820525 23199
  13. ChuckDock
    138
    54
    Jan 7, 2018
    Goodrich, MI
    Local Time:
    11:37 PM
    Ah..that looks more like mine then Frnk's. So it's probably a 3 speed.
  14. Frnknsteen
    542
    315
    May 26, 2011
    Spencer, IN
    Local Time:
    11:37 PM
    Lot of good information on this site about wiper motors in general, though I didn't see a lot on 2spd wiper motors, more on 3spd. Kim from this site is currently rebuilding my '69 3spd wiper motor.
    Welcome to Passion4Mopars - Because Mopars Are My Passion Too
    You could probably send her a picture and see if she can confirm what you have
  15. ChuckDock
    138
    54
    Jan 7, 2018
    Goodrich, MI
    Local Time:
    11:37 PM
    Good call. I'll send her an email.
  16. ChuckDock
    138
    54
    Jan 7, 2018
    Goodrich, MI
    Local Time:
    11:37 PM
    Kim replied back already and confirmed the motor is a 3 speed/variable but didn't know the switch off hand. She asked for its part number so I just sent her that.
    Sounds like I just need to get another switch (bought 2 so far) but get a 3 speed switch, then just re-wire it all for the 3 speed setup. She said if 4 wires go to the wiper motor, its a 3 speed.
    Thats great customer service and I haven't even bought anything, yet..
    • Like Like x 1
    • ChuckDock
      138
      54
      Jan 7, 2018
      Goodrich, MI
      Local Time:
      11:37 PM
      Confirmed on having a 2 speed switch. So I'll just do as planned, if my motor is good, I'll get a 3 speed switch and re-wire it all since the stock stuff looks a little bad.
      Thanks everyone for all your help!
      • Like Like x 1
      • TrailBeast
        TrailBeast Slightly Twisted Member
        19,615
        6093
        Mar 11, 2011
        Arizona
        Local Time:
        8:37 PM
        A bit late but did anyone mention how you can tell which switch you have by how many positions it has?
      • ChuckDock
        138
        54
        Jan 7, 2018
        Goodrich, MI
        Local Time:
        11:37 PM
        Yup, we sure did go over that. I do have the 2 speed switch, but what turns out to be a 3 speed motor.
      • ChuckDock
        138
        54
        Jan 7, 2018
        Goodrich, MI
        Local Time:
        11:37 PM
        Could you tell me how the wires are connected on the motor? Like whats on each spade connector and what goes to the motor, and if anything is doubled up on a connector? Its just hard to tell from the pic and I'm getting a 3 speed switch soon and just want to re-wire my setup to be just like yours.
        Thanks!
      • 4spdragtop
        25,423
        4859
        Aug 28, 2009
        Ontario
        Local Time:
        10:37 PM
        Sorry meant to post pics earlier. Gimme 5
      • 4spdragtop
        25,423
        4859
        Aug 28, 2009
        Ontario
        Local Time:
        10:37 PM
        Heres pics, sorry that's all I got for now. Go to mymopar.com and make sure to download a factory manual
      • ChuckDock
        138
        54
        Jan 7, 2018
        Goodrich, MI
        Local Time:
        11:37 PM
        Thanks for the pics. I do have the manual but it really doesn't show the physical connections.
      • 4spdragtop
        25,423
        4859
        Aug 28, 2009
        Ontario
        Local Time:
        10:37 PM
        Your looking for where they enter the fuse block?
      • ChuckDock
        138
        54
        Jan 7, 2018
        Goodrich, MI
        Local Time:
        11:37 PM
        No, more on the motor side. I see the red, green and brown coming into the motor, along with a black one. The black one looks like it goes to the top spade, and then I see what looks like another black one connecting to the bottom spade. Where does the other end of the bottom black spade go to, ground or the motor?
