67 Barracuda with 383 and ECU… alternative engine harness options?
Electrical and Ignition
  1. Redfoxestco
    Redfoxestco Well-Known Member
    76
    30
    Oct 20, 2020
    Los Angeles
    Local Time:
    4:56 AM
    I’d like to ask if say a 68’ barracuda 383 engine/forward light harness or other a-body engine/light harness could be interchanged and used on my 67?
    I tracked down the only 67’ 383 harness I could find that didn’t have a 3-4 week lead time -but haven’t received tracking or can get ahold of the person. Trying to find an alternative option.
    Thanks in advance!
  2. Mattax
    Mattax Just the facts, ma'am FABO Gold Member
    12,821
    8543
    Feb 7, 2013
    Phila. Pa
    Local Time:
    7:56 AM
    Maybe another '67 Barracuda harness.
    Most of the difference in another '67 B will be wire length and whether the car was tach equipped.
    It's not clear from the assembly drawings if there was a different harness for LA and B engined cars.
    I'd check the parts book to be sure on that.
    '68 is different enough that I would not go that route. You'ld have to move wires to their proper connector cavities and there may be other wiring differences but that would be the big thing. Also '68 tach wire goes through a grommet rather than make conenction in the bulkhead multiconnector.
    Best bet might be to fix what you have, and then circle back to getting a replacement installed later.
    For repair, depending on what is damaged, may need:
    Open barrel crimpers and Chryser terminals, wire strippers. Sources for Chrysler type wire terminals
    Splice connectors and shrink tubing. Inline wiring splice clips........from the Dodge RAM service manual
    Deoxit and other cleaning supplies. What do y'all use to clean the metal connectors that go into the bulkhead on either side of the fw?
    Adhesive free harness tape in couple widths. Vendor needed for cloth / fabric tape non adhesive type
    The '67 service manual diagrams and the Assembly drawings (book from Faxon) will be helpful too. My review of Faxon book, 1967-1969 Dodge & Plymouth Body & Electrical Assembly Manual
    • Thanks! Thanks! x 1
    • Redfoxestco
      76
      30
      Oct 20, 2020
      Los Angeles
      Local Time:
      4:56 AM
      I unfortunately can’t use what I have, previous owner had more Mickey mouses than a Disney cosplay convention. It isn’t an original 383 harness and I can’t find a 67 harness anywhere
    • Mattax
      12,821
      8543
      Feb 7, 2013
      Phila. Pa
      Local Time:
      7:56 AM
      See in the parrts book if the same p/n is used for the LA engine and whether the harness with tach option is different.
      Then once you knowwhat was made, try a wanted ad.
      This way when people ask if you can use a /6 or LA engine harness you'll know the answer.
      As far as ECU wiring - that you'll have to add yourself.
      As far as venders for new.
      Year One sells M&H
      Bill and Rose Evans make and sell their own.
      I think that's about it.
    • cudascott
      cudascott It’s a sickness!
      1,964
      923
      Jan 11, 2012
      TN
      Local Time:
      7:56 AM
      I want to say that the slant 6 harness is the same as the big block but i’m just going off
      my terrible memory.
    • Cuda Al
      Cuda Al Well-Known Member
      1,548
      1810
      Oct 21, 2007
      Lompoc, CA
      Local Time:
      4:56 AM
      In 67 there was only one harness, all engines, all options.
      In 69 there were 3, /6 SB BB
      I didn't check 68.
      In 68 the horn relay was moved into the car so that may impact it.
      Alan
      • Like Like x 2
      • Mattax
        12,821
        8543
        Feb 7, 2013
        Phila. Pa
        Local Time:
        7:56 AM
        Al. Are you sure?
        My '67 HD Barracuda was orignal a 225. The original harness has no tach wire.
        The wires reached everything when I installed a 340, but the routing was not all factory so I wsan't sure if its the same or maybe not.
        The only thing I know for sure was different was the tach wire.
        The assembly drawing lists the following p/n for 1967 engine compartment cable assemblies.
        I interpret that as 2 different main harness for the Barracuda and two different tach wires that maybe were wrapped into the main harness when optioned?
        When you get a repop from Year One/M&H as I did, the tach option is already wrapped in (whether you want it or not).
        Key:
        C/ = 1967 models
        B = Barracuda
        0 = All
        1 = six
        2 = v-8
        - L, H, P = cost level ?
      • Redfoxestco
        76
        30
        Oct 20, 2020
        Los Angeles
        Local Time:
        4:56 AM
        I’m a little confused because multiple companies have the option (albeit out of stock) of an engine / forward light harness combo with ECU?
      • Cuda Al
        1,548
        1810
        Oct 21, 2007
        Lompoc, CA
        Local Time:
        4:56 AM
        From the 67 Parts Book
        Alan
