The stud on the bottom faces in towards the pumpkin. The shock doesnt sit square or flush on it becsuse the upper mounts are the opposite way. Wondering if I have the wrong mounts.
I didnt do it. I noticed it when I had it up in the air to fix brake line leaks. Not sure if they can be turned to go the right direction. I will look closer tonight. The rearend was changed from a 7 1/4 to 8 3/4 by the previous owner.
