67 hood latch cable or assembly
Lisag
New Member
Detroit, MI, USA
Hello, I am trying to find a replacement for a hood latch cable for a 67 b cuda . I am willing to buy the whole assemble if needed.
The 67 Barracuda didn't use a cable, just the lever and rod under the hood.
Alan
someone must of made their own. Mine looks different lol. thanks Do you know if any other year is interchange able ?
For this setup it needs to from a 67/68 Barracuda Fastback, Coupe or Convertible.
Cables came in the 70's don't know much about them. These can be retrofitted in.
Alan
A photo of yours might help in identifying which would be a likely replacement. Lot's of cars starting in the '70's used one. Most of the latches can fit and work. It's mostly the mounting of the cable handle bracket inside that are different.
Welcome to FABO. If you're looking for parts, new or used, You need to start a Parts wanted thread in the Marketplace forums. Because this conversation has already started I'll leave this thread up but move it to the body section.
