RKVS
Dr. Archavious
Looking for a quick ratio borgeson kit if you have it, entire column with p/s length shaft and column shift, pump+hoses + bracket
I have a 1968 Plymouth valiant, /6, Auto, column shift.
Steering column I have is garbage; Reverse and turn signal cams are broken, shifter loose, wheel is crumbling. Live in the city and want to be able to parallel park easier
