[Found!] 68 Barracuda FastBack Outer 1/4 window cat whisker clips
68 CUDA FORMULA S
Clarkston Michigan
I am installing some of the cat whisker back on the 68 and when I got to the rear outer 1/4 window whiskers the passenger side top clip was broken off. Also the factory whiskers have two clips up there where as the replacement ones only have one clip. I am looking for three clips like these ones in the pictures if anyone has some or if anyone know where they can be purchased.
Thanks
Bob
Yep these came already installed on the whiskers and all are good except the one that's broken, I took it off and hoping I can find a replacement for it.
I have contacted the company that I bought the window felts from and they have mailed me out some replacement clips today. Seems like a very good company to deal with, they responded back to me within the hour and told me if I can't get the clips to work they will work something else out for me. So far so good.
When I installed repops(Top Cat) on our fastback, they were a *****. I had to mod a hole on the car to get to fit, fyi.
Glad the company's giving good service. :thumbsup:
This company "repops" has sent me some clips to try and repair the one that was broken, seems easy enough to do. They also told me that if I can't get it to work they would replace the window felt, not to many companies that would offer to do that. Seems like a good company to deal with. All set for now.
Bob
For those of you who ever need to replace these clips do not use a hammer and a punch to try and bend the points over they will just snap off. I tried this method twice and both times the points broke off. In the middle of the night it came to me just bend them over with good needle nose pliers. I tried this in the morning and it worked out just fine. Problem solved.
