[SOLD] '68 barracuda for sale
cudadriver
Winnipeg, Manitoba, CANADA
Rating - 0%
0   0   0
I'm a little nervous making this post. I'm the original owner of this Barracuda notchback and feel it is time to sell so someone else can enjoy it. I don't know the procedure for a sale to the USA if that happens so please keep that in mind. I'm not good with computers so please be kind. I will answer all questions to the best of my memory. I am in Winnipeg, Manitoba, Canada. Asking $15,900
Have all original papers to prove. Original owner's manual with aluminum certicard and warranty book in original plastic pouch. Hand written purchase order and printed invoice, safe motor vehicle dealer's certificate, certificate of registered vendor, original vehicle registration card and original insurance card, down payment receipt and final receipt. 2-broadcasts, build sheets.
Paint is original
Approx 80,000 miles
318 cu. In
Auto transmission
U-joints recently replaced with nos parts
Power steering
Master cylinder replaced two years ago
Original paint in good condition. Passenger door and quarter panel repainted due to a scrape back in the early 70's
Console
Brake and gas pedal chrome trim
Rally speedo
Tach
Light package
New windshield washer reservoir
Thumbwheel Am/Fm radio, not original to the car.
Rear window defogger
Rear speaker with fader control
Under hood pad
“Gills” with rocker mouldings – one year only option
Flip top gas filler lock w/key
Remote mirror
Rear arm rests with ash trays
Original dealer floor mats, front and rear
Optional mag-look wheel discs with chrome nuts
New Cooper tires. Less that 100 miles on them
These are NOS parts
1-original repair manual
1-intake manifold to heads gasket set
1-head gasket set
1-oil PAN gasket set
1-master brake cylinder repair kit
1-starter drive
1-auto trans filter
1-trunk light bulb and switch
1-ash tray (dash) light
1-under hood light kit
1-map light-base and bulb only
2-alternator brush kits
1-ignition switch light relay
1-radio fader control-wire only
1-fuel pump with gasket
2-brake hoses (front)
1-accelerator cable
1-distributor condenser
1-spark plug wire set
1-carb kit
1-pcv valve
1-starter motor brush and plate kit
2-points
1-rotor
3-fusible links
1-gas filter kit (metal)
4-rear axle bearing kits
1-alternator bearing kit (front and rear)
ALL front wheel bearings and races
1-air filter
1-power steering hose (high pressure side)
1-regulator (nos but not Mopar)
1-carb kit (some parts used)
2-U-joint kits
1-tail pipe hanger
1-coolant bypass hose (this is the correct one)
1-upper rad hose
1-lower rad hose
4-nylon spark plug wire mounting clips.
THE FOLLOWING ARE USED PARTS.
1-heater control cable set with fan switch
1-heater box with core and fan (no fan motor)
1-heater core
L&R kick panel insulation
1-heat riser kit (some parts used but ok)
1-dist cap
3-thermostat housing
1-heater fan switch
1-brake pedal pad
1-gas pedal
The ORIGINAL SPEEDO that was in the car
1-carb for parts
1-regulator
2-or more window cranks with gaskets and screws
1-alternator (works)
1-starter relay
1-muffler hanger
Original distributor (needs bushings)
1- air cleaner to carb gasket
1-head light switch
1- wiper switch
ORIGINAL cigarette lighter with correct knob
WHEEL NUTS L&R
1-PAIR wiper arms
Very nice
If I started again knowing what I went threw in restoring our
car, I would buy that in a heart beat.
I will not do this again.
Good luck on the sale.
Darryl
I think your price is fair.
i dont have the cash, but i wanted to say that is an absolutely beautiful car and worth every penny in my book
Great looking car and a fair price! Good luck with the sale.
That is one pretty 68. If it was a fastback, it would be in my driveway by now.
Top honors to you for keeping it is such good shape all these years.
That's a beautiful car for the price you're asking. I couldn't get a single offer on mine on this board. Best of luck with the sale.
This is a really beautiful survivor. I've seen Mike's car in person many times over the years & it looks just as good as in the pictures.
IMHO it's worth every bit of what he's wanting for it.
Good Luck with the sale Mike.
Wish I saw this post 10,000 dollars ago after putting that into restoring my 68 Notch! Worth every penny!! good luck on the sale!!
