They haven’t priced it yet thanksWhat are they asking for it? 45-50k
Hmmmmmmmmmm I'll never understand having a vehicle offered for sale but no price. Good luckThey haven’t priced it yet thanks
It has dual exhaust but the pass side muffler is barely visible in the 2nd pic.Hard to tell in pics, but all had dual exhaust. You should check the numbers yourself- VIN, engine, trans, radiator support and trunk W/S. Air cleaner is not correct. This is a very low option car. I am suspicious- bid low.
I can get more pictures I don’t live far from the car. I knew what it looked like before it was restored. Thanks
Hagerty values this car in #2 (excellent) condition at $31,800.
thats for a run of the mill notch, old cars lists #2 383S as plus 30% or 41k and #1 is priced at 45k plus 30% or 58.5k.
condition is everything, if I were you I would have it appraised and inspected by a mopar expert. you need the build sheet to match the sequence number stamped on the motor, trans, radiator support and under the trunk gasket with the vin number on the dash. all stampings must match. the build sheet is the only way to document this car, if its missing car would be less money.
