I have a GTS here in my shop with stock 383 manifolds, the drivers wrap around the column making engine removal with manifold a bugger, so is it best to pull column and leave manifold on or?
I just did this one that way the other day but that was a complete build.
The Dart I was going to try and be sneaky and just pull engine since all I needed to do was repaint/detail engine and install some top end goodies, no clutch work.
Should not try to be sneaky?
Really depends on why you are pulling the engine. If just doing a refresh and the suspension is fine, take off the passenger manifold and unbolt the drivers side and tie it out of the way. If doing work on the suspension then take it out from underneath, done both multiple times.
Going back in I go to the bicycle shop and get a bicycle box, and put it over the motor from right to left and when its in place just pull the cardboard straight up off the engine. no scratches, dents or dings.
We did get it out today through the top with removing manifold driver side as engine was lifted, it was sooo tight No Band-Aids even.
Reverse of this procedure we and you guy's will agree is going to be a *****.
# s matching block even, customer had no idea.
I have an engine swap coming up (smallblock) and every swap I've done has been out the top.
Suspension and everything is good, so leery of bringing it out the bottom. Also never removed torsion bars before, so not sure what's involved there.
