68 marker lights
Mopar Body and Trim
  1. Mike 340
    Mike 340 Well-Known Member
    131
    37
    Jun 21, 2016
    Canada
    Local Time:
    12:49 AM
    Has anyone ever seen a 67 dart gt with 68 marker lights? Factory installed.
    The reason I ask this is I have one.
    I am the 3rd owner of the car and I know the previous owners . Also how would I be able to prove this. I don't have a build sheet but I have the fender tag.
  2. oldkimmer
    oldkimmer FABO Gold Member FABO Gold Member
    10,453
    1296
    Nov 11, 2006
    Kindersley, Saskatchewan,
    Local Time:
    11:49 PM
    .................67 had no marker lights.....U can't prove what didn't happen............kim........
  3. RedFish
    RedFish Well-Known Member
    23,053
    2002
    Sep 5, 2007
    Local Time:
    11:49 PM
    Nothing more than a hole saw red'q to install the round side markers. I've seen them added to pickup trucks. You would need some sort of stampings in the body panels to prove OEM.
  4. momoparman
    momoparman MOISMYHOME
    3,147
    318
    May 31, 2008
    M I Z Z O U
    Local Time:
    11:49 PM
    A 1 of none car huh?
  5. BIG-B-Barracuda
    BIG-B-Barracuda Well-Known Member
    1,133
    93
    Dec 25, 2011
    CALIFORNIA
    Local Time:
    11:49 PM
    or previous owner found some 68 fenders for a 67 that needed a set of fenders>?
  6. Mike 340
    131
    37
    Jun 21, 2016
    Canada
    Local Time:
    12:49 AM
    The car has been in my family since 1975. My father bought it off his boss the original owner. He bought the car from Pembina Dodge in Winnipeg in December of 1967.
    All sheet metal is original. The lights are a stamped holes. I did not put these lights in
    And my father did not or his boss. The car is a late June of 1967 build.
  7. momoparman
    3,147
    318
    May 31, 2008
    M I Z Z O U
    Local Time:
    11:49 PM
    OK.
    Believe what you want, but it did not happen at the factory unless you can prove it did. A build sheet would not do that.
  8. BIG-B-Barracuda
    1,133
    93
    Dec 25, 2011
    CALIFORNIA
    Local Time:
    11:49 PM
    hmm....
  9. momoparman
    3,147
    318
    May 31, 2008
    M I Z Z O U
    Local Time:
    11:49 PM
    If you really want to know, you could contact Galen Govier.....he knows everything.
    Galen's Tag Service, LLC
    Let us know what he finds.
  10. 72bluNblu
    72bluNblu FABO Gold Member FABO Gold Member
    9,171
    3181
    Nov 28, 2008
    NorCal
    Local Time:
    9:49 PM
    Correct me if I'm wrong, but don't the '68 fenders just have a hole? There's no flange, or rolled edge or anything. Just a round hole with a small indent in the hole to index the light.
    What I'm getting at is there would be pretty much no way to tell if the hole was factory or added later unless it was added in the wrong spot or poorly executed.A stamped hole and a hole saw cut hole with a smoothed edge prepped for paint look the same, and the indexing mark can be added carefully. And yes those are '68 sidemarkers on the front of my Duster. Soon to be the in the rear too. It's very simple to add them.
    Unless you've held your fender in bare metal up next to an original '68 in bare metal it would be nearly impossible to tell if the job was done well. Maybe you could use a set of calipers do measure a handful of '68 marker holes and see if they're the same size, a stamped hole can be any size while the cut hole would at least start a standard size. Although that assumes all the original marker holes are very close to the same size, which they might not be, especially over the entire production run.
    And, if the car wasn't purchased until December '68 it would have been on the lot quite awhile. Maybe an enterprising young employee decided that leftover '67 could be made to match the '68's? Maybe a buyer liked the new '68 lights and wanted them on that leftover '67 but the sale fell through? Dealers added a lot of stuff back then.
    The production lines ran into July sometimes late into July before things stopped for retooling. A late June build having '68 markers would mean there would still be at least a couple, if not several weeks of production being built like that. Meaning, a lot more then just one car would be like that if the factory had started using the '68 markers early.
    • Like Like x 1
    • zigs
      zigs Well-Known Member
      1,953
      156
      Apr 10, 2010
      Yakima, Washington
      Local Time:
      9:49 PM
      When I first bought my 68 the passenger side finder was screwed up had to replace it. The only thing I could find local was a 67 finder. Took a couple measurement from the driver side , drilled the hole and put the marker in . Nobody new the difference.
