69 Barracuda convertible how to remove back seat?
56Steve
Liberty, MO
I am trying to remove my bottom back seat and the seat back, has any one had luck doing this?
Thank you!
56Steve
Push the bottom portion of the seat toward the rear of the car as far as possible while firmly pulling up on the front edge.
There are two “clips” one on the right and one on the left, that allow you to release the seat bottom.
Once you get the bottom out there are two screws on the lower part of the back. Remove those screws and lift up on the seat back to remove it.
Make sure you have to convertible boot either removed from the rear of the seat back or un-snap it from the rail in the trunk.
This is what is under your seat on either side on the floor
