[WANTED] 69 Barracuda convertible rear interior panels
raven64
cal
Rating - 0%
0   0   0
hi everyone,
in search of a set 69 Barracuda convertible rear interior panels in yellow
thanks
i have one in black.... [PASS SIDE] only a few tiny cracks in the normal upper arm area where the screws go into it.. been in storage since 77.. 350.00 shipped usa or pick up in seattle
We have brand new reproduction convertible rear interior panels in stock here in our warehouse and ready to ship. These panels come with the chrome trim and arm rest pads already installed. They do NOT come with the ash trays or the courtesy light at the bottom.
We have these panels in either BLACK or WHITE. If you're looking for yellow panels, you'd want to get a set of white and have them sprayed to your shade of yellow.
AF-PRO1P- BLK, (for BLACK panels)...1967-69 A-Body....Pair...$798 plus S/H
AF-PRO1P- WHT, (for WHITE panels)...1967-69 A-Body....Pair...$798 plus S/H
hello,
very nice. do they have the same grain as the originals ?
The upper section is smooth like originals and the lower section does have a grain pattern like originals.
These are New Reproduction injected molded rear convertible side panels for your 1967-69 A-Body Mopar. Exact reproductions for 67-69 Darts and 99% exact for the 1967-69 Barracuda. The Barracuda has a slight curve on the very top of the panels whereas the ones we are tooling from are Darts that are flat. We will have stocked on our shelves either Black or White. Original textured finish on the bottom of the panel as well as the smooth surface on the top end. Between these two surfaces is a NEW replacement chrome trim as well that is sold separately IS included with these panels (See # TL-2787948). This panel also comes with NEW armrest pads as well!!. Our New Arm rests are a bolt-through design for better mounting and won't be prone to falling off as the originals once did..
Please Note - The top smooth sections on these panels are not finished and will show some sanding marks within the panel. They would be needing some additional sanding and prep-work in order to paint them to perfection.
