69 Barracuda Sport Package Sill Molding
Mopar Body and Trim
  1. 1969cuda
    1969cuda Well-Known Member
    790
    793
    Sep 9, 2007
    California
    Local Time:
    7:03 PM
    No problem, glad to help.
    • Thanks! Thanks! x 1
    • IMFURYS
      IMFURYS IMFURYS FABO Gold Member
      266
      144
      Aug 9, 2013
      Portsmouth, VA
      Local Time:
      10:03 PM
      Check out this thread, especially post 15 of another thread on the black paint. I can't say if it's completely correct, not many pictures anywhere to compare it to: [WANTED] - 1969 Plymouth Cuda Rocker Molding
    • IMFURYS
      266
      144
      Aug 9, 2013
      Portsmouth, VA
      Local Time:
      10:03 PM
      Well, if you're able to reproduce them, I'd be interested. I went back thru the moldings that were in the car when I got it (stolen, stripped and various trash/ parts piled in it). I pulled one out, like I had before, held it up to the bottom and said yep, this is it (again no clips at all). I then pulled out the other one, it was longer, so it's from a Valiant or the Dart/Dusters that look the same but are longer. So unless I misplaced one somewhere else, I only have one side. So I hope you can re-pop them, or I may try the Classic Industries dart/duster repops and have them cut down and the edge rolled just right. Other choice is to weld up the holes and not worry about it for me, but I was liking the fact that not a lot of other's had the Sport Package, so no sill molding. Also mine is going to have a NOS clock that was converted to quartz movement instead of a tach or "performance indicator". @moparmat2000 has been fixing me up with some nice other mods, like the dual dash speaker mount and a custom console wiring harness that will have LED lights in a couple of discreet places to light up the areas better. Just a few discrete mods, since I was shooting for that "factory look".
    • 1969cuda
      790
      793
      Sep 9, 2007
      California
      Local Time:
      7:03 PM
      In the pic I posted, the top left clip is a reproduction that does/will C77565C7-F1B3-4FC4-8D07-6B5D48282C23.jpeg not work, the top right clip is the first clip for either side on the front fender, and the bottom two are originals that have broken tangs. No part numbers on them what so ever. I have twenty or so of them, in various states of disrepair.
    • IMFURYS
      266
      144
      Aug 9, 2013
      Portsmouth, VA
      Local Time:
      10:03 PM
      I'm sorry, but is there a pic or two missing? It's cool to see the fender clip, as I thought they were all the same, but I don't see the reproduction or clips with the broken tang. Thanks for letting us know the fender is different and how they look installed on a '69. I'm just bummed that I thought I had a set, but guess I just have one side. Have to decide which way I'll go, when I get to that point.
    • moparmat2000
      moparmat2000 FABO Gold Member FABO Gold Member
      16,061
      5280
      May 13, 2010
      Grand Tetons
      Local Time:
      9:03 PM
      Dan fill the holes in the body and sell it for 1 million dollars. All your problem is solved
    • IMFURYS
      266
      144
      Aug 9, 2013
      Portsmouth, VA
      Local Time:
      10:03 PM
      I may fill in the holes, we'll see, but I ain't letting her go for less than a case of TP and 2 bottles of hand sanitizer.
      • Like Like x 2
      • moparmat2000
        16,061
        5280
        May 13, 2010
        Grand Tetons
        Local Time:
        9:03 PM
        Damn, that is worth more than a million bucks. You drive a hard bargain.
        • 1969cuda
          790
          793
          Sep 9, 2007
          California
          Local Time:
          7:03 PM
          Here is the pic I missed.
          The two bottoms clips are shown front and back. You can see what’s left of the broken tangs.
        • 69'Barracuda
          69'Barracuda Well-Known Member
          317
          38
          Jun 27, 2016
          Fort Riley Kansas
          Local Time:
          10:03 PM
          If I get a complete set, I can look at getting a shop to build new ones out of stainless instead of anodized aluminum. The clips, I’m going to try to find a good condition clip, and 3D scan it and print it. Those would be much easier to reproduce.
        • moparmat2000
          16,061
          5280
          May 13, 2010
          Grand Tetons
          Local Time:
          9:03 PM
          The end metal clips you can probably find something for another make vehicle that will work. Try AuVeco clips and fasteners. They may have something close.
          Having these made from stainless steel would be much better than the anodized aluminum.
        • 69'Barracuda
          317
          38
          Jun 27, 2016
          Fort Riley Kansas
          Local Time:
          10:03 PM
          The metal clips look easy enough to, again, have scanned in like the plastic and then just laser cut out of a stainless steel sheets so rust isn’t a problem. While I don’t have the capacity for that where I am currently, I have tons of friends with tons of friends I’m sure I can find someone easily, I’d be glad to do the work to have all this stuff repoped and then sell it back off at slightly above cost.
        • davescuda
          davescuda FABO Gold Member FABO Gold Member
          9,862
          1457
          Apr 30, 2007
          Cheshire, CT
          Local Time:
          9:03 PM
          I thought I had some nos clips but they don’t look the same.
        • 69'Barracuda
          317
          38
          Jun 27, 2016
          Fort Riley Kansas
          Local Time:
          10:03 PM
          Got my hopes up lol. I've found one side, but still looking for another or a complete set if another spare cant be found.
        • 1969cuda
          790
          793
          Sep 9, 2007
          California
          Local Time:
          7:03 PM
          Close, but no cigar. These clips are extremely hard to find in usable condition.
        • IMFURYS
          266
          144
          Aug 9, 2013
          Portsmouth, VA
          Local Time:
          10:03 PM
          My TP dealer came through big time last night. Got me a 24 roll pack of Angel Soft. I'm gonna cut it with some fast food napkins from the glove compartment, then already got people wanting it. Got a mule to deliver it too. I knew I'd find a way to finance my Mopar projects, lol.
        • IMFURYS
          266
          144
          Aug 9, 2013
          Portsmouth, VA
          Local Time:
          10:03 PM
          Wow, they do exist. Thanks for the pics, pretty sure I've never seen them.
        • davescuda
          9,862
          1457
          Apr 30, 2007
          Cheshire, CT
          Local Time:
          9:03 PM
          what do they measure?
        • IMFURYS
          266
          144
          Aug 9, 2013
          Portsmouth, VA
          Local Time:
          10:03 PM
          We should be able to.
        • moparmat2000
          16,061
          5280
          May 13, 2010
          Grand Tetons
          Local Time:
          9:03 PM
          Pretty sure the white clip on the left is available through AuVeco clips and fasteners. It snaps into raised spot welded lugs. These can easily be installed with pop rivets. If not theres plenty of GM clips there for wide rocker mouldings.
        • moparmat2000
          16,061
          5280
          May 13, 2010
          Grand Tetons
          Local Time:
          9:03 PM
        • 1969cuda
          790
          793
          Sep 9, 2007
          California
          Local Time:
          7:03 PM
          Those clips are sold by fmmpar on eBay, specifically for these moldings, but do not fit.
          • Agree Agree x 1
          • IMFURYS
            266
            144
            Aug 9, 2013
            Portsmouth, VA
            Local Time:
            10:03 PM
            I had read that awhile back, can't remember who had posted it, but it made me stop from ordering them.
          • 1969cuda
            790
            793
            Sep 9, 2007
            California
            Local Time:
            7:03 PM
            That was me
          • IMFURYS
            266
            144
            Aug 9, 2013
            Portsmouth, VA
            Local Time:
            10:03 PM
            Sorry couldn't remember who had said it, just remembered what you said. You kept me from ordering them, so thank you for that. Of course finding out I only had one side put a damper on it too, lol.
          • 1969cuda
            790
            793
            Sep 9, 2007
            California
            Local Time:
            7:03 PM
            Here are some closer pictures that show actual size and part number fwiw. D3D03610-6A7C-4981-A47E-58B23F56D1E3.jpeg 2AC30398-200A-448C-AE8E-2C7CFA086D00.jpeg
