69 dart disc brake conversion with 14" Crager SS rims
Brakes for your Classic Mopar
  1. agepag
    agepag Well-Known Member
    62
    7
    May 4, 2010
    Richmond Hill Ontario
    Local Time:
    11:07 AM
    So was about to do this conversion, but from what I have been reading and been told this is not possible. PirateJack (which sells MBM) says it will not fit. Still waiting to hear back from Doctordiff. Has anyone ever successfully done a front disc conversion with the same setup? Worst case I will just go powerbrakes.
    Thanks
  2. 694spd
    694spd Well-Known Member
    785
    164
    May 2, 2014
    Upstate NY
    Local Time:
    11:07 AM
    Are you talking about going to a 4 piston KH set up or a 73 and later single piston caliper?
    With the KH there will be no issue....
  3. agepag
    62
    7
    May 4, 2010
    Local Time:
    11:07 AM
    I want to go with whatever will work! THe 73 and later will require me to piece it together. What is the KH kit? Sorry I am fairly new to all this!
  4. 694spd
    785
    164
    May 2, 2014
    Upstate NY
    Local Time:
    11:07 AM
    KH is the Kelsey Hayes disc brake set up that was OEM on the A-bodies up to 1972.
    Probably cheaper to go with the 1973 and later single piston disc brakes, assuming that they will clear the 14" wheels.
  5. agepag
    62
    7
    May 4, 2010
    Local Time:
    11:07 AM
    Ah ok, so this is OEM, not a kit I could buy. I am still searching to see what will work, I am hoping someone will have upgraded to Disc that run 14" Crager SS rims. I think the MBM kit will fit but the calipers may need to be shaved down a bit.......The search continues!
  6. Dubob
    Dubob Well-Known Member
    1,162
    354
    Oct 28, 2011
    Ohio
    Local Time:
    11:07 AM
  7. agepag
    62
    7
    May 4, 2010
    Local Time:
    11:07 AM
    Thats what I thought, but they sent me an email and said it will not work with cragers
  8. JoeDragster
    JoeDragster FABO Gold Member FABO Gold Member
    225
    30
    Jul 14, 2004
    Longview, Texas
    Local Time:
    10:07 AM
    Let me lnow what you find out. I have a beautiful set of 14” on 4” cragers with drum brakes and no booster. To say the least. I dont want to buy different rims so my options are limited.
  9. ddartdude
    ddartdude Well-Known Member
    536
    138
    Jan 1, 2007
    Port St. Lucie, Florida
    Local Time:
    10:07 AM
    I have SSBC disc brakes on the front of my 66 Dart GT. I have small bolt pattern Cragar SS's on it. They just clear the metal caliper brake lines. The part number is A153. They are not cheap.
    I have to redo the front metal lines from the master cylinder because whoever ran them really butchered them up.
  10. diymirage
    diymirage HP@idle > hondaHP@redline
    14,771
    7110
    Oct 12, 2012
    michigan
    Local Time:
    11:07 AM
    Scarebird should fit
  11. JAG
    JAG Member
    9
    0
    Dec 18, 2017
    Lincoln, ON Canada
    Local Time:
    11:07 AM
    Last year I did a front brake disc conversion using a kit from Summit, SSB-153. Can be small or large bolt pattern. The kit had everything that was required to do the conversion including the master cylinder. It also works with my 14" SS cragers. Was fairly straight forward and easy to install.
  12. JAG
    JAG Member
    9
    0
    Dec 18, 2017
    Lincoln, ON Canada
    Local Time:
    11:07 AM
  13. JAG
    JAG Member
    9
    0
    Dec 18, 2017
    Lincoln, ON Canada
    Local Time:
    11:07 AM
    Last year I did a front disc brake conversion on my 68 Dart using a SSB-153 kit from Summit. You can use either small bolt or large bolt depending on your rims and I stayed SB with my 14" SS cragars to be the same as the rear. The kit had everything that was required to do the conversion including the master cylinder. It was fairly simple and easy to install.
